...same here. I have discovered that some morphs disappear if you have rendered a scene, saved it as a pz3, then - later - re-open the scene... If you look for them you will find all the dials for the morphs... e.g. "open mouth" is set to 1.0 but the mouth of that figure is closed. Nothing happens at 1.0, at 0.0 and back again to 1.0. The only workaround for me - to delete that special morph and to "install" it once again. A.
Maybe no one used it or noticed it, but if you use the reset button on the diles, sometimes, it stops working. And I also notice at one point that I was no longer able to change the values that I typed in. Even after typing in zero, it went back to the preview value. These bugs were found after using the parameters.
