When you uninstalled did you remove (or rename) the installation directory ?
The uninstaller may have left some files in the PP directory, which the installer won't replace.
Try installing to a completely clean directory and see if that fixes it.
Be sure to take a copy of the contents of the top-level directory once you got your interface setup as you can then copy the files back if your installation get corrupted again (one to watch out for is Poser.rsr).
Saving a copy of the Runtimeprefs (I think) files is also useful.
What error do you get. I just reinstalled Poser 4, Pro Pack, Poser 5 and Poser 6 without any problems. I installed Poser 4 twice in differant locations on my hard drive and then patched both installations with the Poser 4.03 patch. I then installed Pro Pack onto one of the Poser 4 installations. Worked fine - WinXP Pro is my OS. FYI, Clint
Clint Hawkins
All my life I've been over the top ... I don't know what I'm doing
... All I know is I don't wana stop!
(Zakk Wylde (2007))
Thanks, I installed to a clean directory; then tried with only the poser setup, then tried with poser setup plus 4.03 update, then with update plus memory update. It didn't work. In fact the 4.03 update begins to load then searches for components, then disappears. My current version is now 4.0.3.127. Is this the updated version? Did the patch load or not? How can I install ProPack?
Message edited on: 06/05/2005 10:34
My ProPack gives 4.2.1.179 as the version number (that's after installing SR3), I think that the original PP was 4.1
If, as your version number suggests, you bought PP as an add on to P4 you should have a seperate installer.
I think that you need to install PP SR3 before running it to avoid activation problems.
sr3 is a service release to patch Pro Pack, you will need to install poser 4 install propack install propack sr3 If this all fails contact e-frontier they will be more then willing to try to help you with this.
โ ฮฉ Poser eZine
ฮฉโ
โ ฮฉ Poser Free Stuff
ฮฉโ
โ ฮฉ My Homepage ฮฉโ
www.3rddimensiongraphics.net
ย
Thanks to all for your help. I ran System Restore back to Thursday, then tried to run Poser -- nothing. I reinstalled Poser and the service releases on top of it. It runs Pro Pack now, though I still cannot reinstall Pro Pack -- Also the following error appears: Cannot open script for reading: (PEPythonEngine::DoScript()) So I have version 4.2.1.179 running now. I still would like to reinstall Pro Pack so everything is a clean install. Any ideas?
You seem to be missing the actual ProPack installer.
My installer (for P4) is called "Setup.exe".
I also have "Poser4MemoryUpdate.exe" and "Poser403Updater.exe".
My installer (for PP) is called "Pro Pack Setup.exe".
I also have "ProPackMemUpdate asi .exe" and "Pro Pack Service Release 3.exe".
Hope this helps you locate the file.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Thanks, Debbie,
Autorun didn't start -- so I followed the directions in the booklet and double clicked the .exe in the cd dir -- I don't know what the trouble was. I had a similar problem when I originally installed it but don't remember how I solved it. It still will not install from the cd. I guess that there is a software conflict somewhere.
I restored my system to a time before I uninstalled, and once I recopied the files into the CL directory over the old installation, it ran fine except an error about a Python script not existing. I installed the latest Python, monkeyed around some more and now Pro Pack runs fine. Although I got a strange error about quota (memory?) today while loading a giant DNA model... But overall the program is back to normal and the robots are rendering busily.
Thanks to everyone for your help.
Message edited on: 06/07/2005 21:08
I installed Pro Pack last year and it worked fine. Today I somehow corrupted my Poser installation and so uninstalled, cleaned the registry, reinstalled. Now Pro Pack will not install. It begins to load then gives an error. I've seen other threads about this problem but none with a solution. There is no option to manually locate the Poser installation. WinXP
