Carrara F.A.Q (Last Updated: 2025 Jan 26 7:05 pm)
I've had that problem, too. I will have to try with Full Raytracing.
I'm having trouble rendering a scene. It's the DAZ scene I inquired about earlier. Above you can see the problem; when the rendering camera is in certain positions, the foreground of the floor doesn't render. (As you can see here, some elements closer to the camera do render, like the manhole cover.)
I've had this problem before, so I'm pretty sure it's not just the scene I bought from DAZ....
I started this on Carrara 3 and then when the problem occurred, went ahead and installed C4Pro (which I bought in February but have been too busy to install). The same problem happens in both versions.
I'm using WinXP on a machine with a gig of ram and a 2.93 GHZ Pentium 4 processor.
Any ideas? Help!
Thanks!
Dex
