Tue, Feb 4, 8:22 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Rendering problem
sfdex ( ) posted Mon, 06 June 2005 at 11:50 PM · edited Mon, 03 February 2025 at 3:29 PM
Hi, all --
I'm having trouble rendering a scene. It's the DAZ scene I inquired about earlier. Above you can see the problem; when the rendering camera is in certain positions, the foreground of the floor doesn't render. (As you can see here, some elements closer to the camera do render, like the manhole cover.)
I've had this problem before, so I'm pretty sure it's not just the scene I bought from DAZ....
I started this on Carrara 3 and then when the problem occurred, went ahead and installed C4Pro (which I bought in February but have been too busy to install). The same problem happens in both versions.
I'm using WinXP on a machine with a gig of ram and a 2.93 GHZ Pentium 4 processor.
Any ideas? Help!
Thanks!
Dex
Sydney_Andrews ( ) posted Tue, 07 June 2005 at 12:51 AM
Ive had that problem before and when i turned on "Full Raytracing" i didnt have that problem any more. Another thing you could check to see is if there is a ground plane there that shouldnt be. Good luck E
MarkBremmer ( ) posted Tue, 07 June 2005 at 4:45 AM
Using Echo871's suggestion or turning off interpolation will also work.
sfdex ( ) posted Tue, 07 June 2005 at 8:48 AM
Thanks for the quick responses! I'll give those ideas a try when I get back home tonight. Thanks! - Dex
sparrownightmare ( ) posted Sun, 12 June 2005 at 3:41 PM
I have had the same problem as well, but only in test renders. I use full raytracing for my final renders and that being on seems to fix the problem for me as well.
ShawnDriscoll ( ) posted Sun, 12 June 2005 at 4:25 PM
I've had that problem, too. I will have to try with Full Raytracing.
sfdex ( ) posted Sun, 12 June 2005 at 9:12 PM
It did work -- the scene renders perfectly now! Thanks again for the tips! - Dex
