Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
I suspect that the paths aren't actually touching each other. They MUST connect or you can get disappearing content. When drawing to or from an existing path, hold the Shift key. It will show a little, white cross-hair that will snap to the line and/or beginning and end points as you move the cursor over an exiting line. Put it where you want it and then click to begin drawing.
When trying to create a 3D object using any of the surface modeling tools with spline/bezier paths of any type, the paths disappear upon applying any of the surface modeling tools and no 3D shape results. Basically applying the surface modeling tools to line paths simply deletes the paths but yields no 3D object. Has anyone else experienced this and or have any solutions? Thanks.
