Wed, Jan 29, 7:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 7:12 pm)
Subject: How to export figure with STRAND hair to Carrara?
vernonglen ( ) posted Tue, 07 June 2005 at 4:24 PM · edited Wed, 29 January 2025 at 7:31 PM
When I export James into Carrara he exports fine, but Strand hair doesn't cross over. What is the trick please? Anybody? Thanks in advance gang. Vernonglen
milamber42 ( ) posted Tue, 07 June 2005 at 4:58 PM
What version of Carra, Transposer, and Poser are you using?
vernonglen ( ) posted Tue, 07 June 2005 at 5:15 PM
I am using Poser 6 and Carrara 4 standard. I have used the Poser export function to export files as Wavefront Objects in Poser and then brought the file in as imported Wavefront files in Carrara. I am prompted by Carrara then to locate some of the textures for the skin and clothes. Except for the Strand hair it works pretty good. What's Transposer? I work on a 1GHz PowerPC G4 Mac Power book in OS 10.3 with 1GB DDR SDRAM. vern
milamber42 ( ) posted Tue, 07 June 2005 at 5:20 PM · edited Tue, 07 June 2005 at 5:29 PM
Attached Link: http://www.eovia.com/products/carrara_addons/transposer.asp
Transposer is an add on that allows you to open PZ3's directly into Carrara. AFAIK, Transposer 2 is the only way to import P6 hair into Carrara. I forgot that TransPoser 2 works w/ Poser 5 only at this time. e-Frontier has not released the SDK for Poser 6, so TransPoser 2 has not been updated to work w/ Poser 6.
Message edited on: 06/07/2005 17:29
