Mon, Feb 10, 8:35 AM CST
Subject: Trouble editing cr2
barbie4364 ( ) posted Wed, 08 June 2005 at 12:06 PM · edited Sun, 09 February 2025 at 5:52 PM
Hello! I am trying to edit a cr2 file which was created with poser 6. When I open the file in wordpad, everything looks fine, I just cant type anything in the file. I cant make any changes to the file at all. Its like a lock is on or something. Does anybody know what to do to get this to work? Thanks Lonni
nickedshield ( ) posted Wed, 08 June 2005 at 12:47 PM
Are you running P6 with compression on? If so, you'll have to uncompress the file before you can edit it. There should be a Python script in the Python Pallet that will uncompress. If it's not that, make sure the cr2 is not write protected.
kuroyume0161 ( ) posted Wed, 08 June 2005 at 1:15 PM
Also, make sure that Poser is not running while editing - it will not take.
 -- Bjarne Stroustrup
barbie4364 ( ) posted Wed, 08 June 2005 at 8:17 PM
There must be something wrong with my wordpad. I checked and my p6 compression is not checked. I also looked at the properties of the cr2 and dont see that it is write protected. I also tried editing after closing down poser completely. It still wont let me edit the file. Is there someplace else to check to see if it is write protected? I checked the properties after right clicking the file in windows explorer. I am running windows xp. Thanks for the suggestions!!! Lonni
kuroyume0161 ( ) posted Thu, 09 June 2005 at 1:09 AM
Maybe it's too large for WordPad. I'd use something else. Personally, I use UltraEdit32. There is also a free editor called NoteTab Lite. Don't use Word, NotePad, or WordPad.
R_Hatch ( ) posted Thu, 09 June 2005 at 1:14 AM · edited Thu, 09 June 2005 at 1:15 AM
Ewww, WordPad.
Use CR2Builder instead :)
Get it here Use the one labeled "CR2Builder02h18.zip (h18) Feb 14, 2004".
Message edited on: 06/09/2005 01:15
xantor ( ) posted Thu, 09 June 2005 at 2:42 AM
Textpad is another program that is better to use than wordpad. Textpad can load any size file, too.
