Sun, Feb 2, 6:08 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: Deleting Materials
Robo2010 ( ) posted Thu, 09 June 2005 at 10:16 AM ยท edited Thu, 01 August 2024 at 10:59 PM
Is their a way to delete materials, that the mesh already has been grouped and put in its own created material. (Hope that made sense). I want to delete: Default #s
neilp ( ) posted Thu, 09 June 2005 at 10:34 AM
Open the File in notepad and go to the bottom of the file where you will find the material section. It should look something like Material Default #s { blah blah blah . . etc } If you delete that section, save the file and reload it your material will be gone.
EnglishBob ( ) posted Fri, 10 June 2005 at 4:19 AM
Open the mesh in UVMapper. Select by material, and choose all the materials you want to amalgamate. Then do assign to material, choose a new or existing name, and save. If you do the text hacking,the areas from which you remove the usemtl lines will adopt the material from the previous section. That may be what you want, or it may not. The only true way to have no materials at all assigned to part of a model is to have those facet lines at the beginning of the block, before any usemtl lines. In that case, Poser would use the default material for those areas.
