Fri, Dec 27, 7:07 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Subject: Silly question
whirlingfeather ( ) posted Thu, 09 June 2005 at 7:09 PM · edited Fri, 27 December 2024 at 6:52 PM
Hello all apophysis users, I have a probably simple question to ask but I cannot figure it out on my own. How do you preview your complete image at the size specified. For example:Say I wanted to make the height larger than the width...is there a way to preview this before rendering or exporting the flame? I would appreciate any help at all! Thanks in advance, Treena
Pontigary ( ) posted Thu, 09 June 2005 at 8:10 PM
Lets suppose Your image is high (twice higher than the width). First of all You can resize the render window size (CTRL+I) by entering the exact numbers (if Your screen resolution 1600 x 1200 enter width - 600 and hight - 1200 - it will make the render window exactly the size You need) or use mouse to resize the whole Apo window to the proportions You need. Than You can use Ctrl+A (Adjust) to make the render window the optimal size for the flame not to be cropped. In Adjust applet preview You'll see the dimensions of Your resized render window already. Did it help? With kindest regards, -Anthony.
whirlingfeather ( ) posted Thu, 09 June 2005 at 9:12 PM
Thank you very much, I will work on it! Treena
