Sat, Feb 8, 7:40 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Height of infinite plane?
FranOnTheEdge ( ) posted Sat, 11 June 2005 at 10:34 AM · edited Sat, 08 February 2025 at 5:35 AM
Hi, I'm trying to follow the tutorial but when it says "set the height to 0,005" I can't see how to do that. I've tried doing it in this window above, but the program says "unrecognised... something" and goes back to the original height. Help? Fran
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
mmoir ( ) posted Sat, 11 June 2005 at 11:02 AM
Hey Fran, Which tutorial are you doing, the one on Eovia's site by Cajomi. If so the area you have circled changes the height of the Mountains where I think you want to raise the height of the infitie plane or water in the assembly room. When in this terrain editor window click the "hand" icon top right of GUI to take you to assebly window , select the infinite plane object and raise the position to .005. You are just trying to place the water at the correct elevation with respect to the terrain object. Good luck.
FranOnTheEdge ( ) posted Sun, 12 June 2005 at 10:38 AM
No, it's the Johannes one. (not sure of the spelling there) and it's meant to Lower the height of the terrain as it will become the water. And before the image I posted I was IN the assembly window but couldn't see how to "select the infinite plane object and raise the position to .005." as you put it, so how do you actually raise or lower the terrain's height? What should I be clicking on in that assembly room/window?
Fran's Freestuff
mmoir ( ) posted Sun, 12 June 2005 at 11:14 AM
Cajomi is Johanne's username in some forums. In the assembly window use the manipulator to move the selected object up and down. I will look at the tutorial on eovia's site to know more of what you are talking about. Mike
Patrick_210 ( ) posted Sun, 12 June 2005 at 11:42 AM
In the assemble room, in the right hand tray there are 4 tabs at the top. You must have your plane selected, and the click on the "motion" tab. Then look to the "transform" box below, click the little triangle there, if it is not open. "Center" is the first row of values, and "z" will set the height. Patrick
