the sattelite dish looks cool..very sci-fi :) you might also want to split the vertices on the obj to take care of that over smoothing..or set the 'crease' dial down to a low number Stefan
the first two pics you posted have bad shading on the faces,especially under the windows,..what almost look like shadows but aren't. split the verts or lower the creasing angle for the object & you should see what I mean. hope that helps Stefan
![file_255543.jpg](https://live.cdn.renderosity.com/forum/threads/2302482/file_255543.jpg)
What makes parts of a Mesh dissapear? I can never figure this out. Most parts of a Mesh is ok, but then other parts are invisible. Depending on camera angles, they appear, and go invisible. Can it be fixed?Message edited on: 06/16/2005 09:27
