Sat, Nov 30, 1:15 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Scripting Question/Request
Terry Mitchell ( ) posted Sat, 10 February 2001 at 7:03 PM · edited Tue, 26 November 2024 at 8:38 PM
Is there a script for adjusting figures that have BHVs imported to them so that they will walk on the floor instead of up in the air? (The old way was to manually adjust each keyframe in the resulting animation.) Also, how about one to "batch delete" those RSRs and BUMs that apparently aren't needed any more. Or one to "batch apply" Bushi's Morph Squeezer to all the morph files at once? Are any of the foregoing actions possible to do with a Python Script?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
bushi ( ) posted Sun, 11 February 2001 at 12:36 AM
Hmmm ... I don't know about the BHV stuff since I haven't worked much with the animation side of Poser. The 'batch delete' and 'batch apply' are both possible. There has been some debate here about the possibilities of nuking a system using PoserPython. As a result, the delete program might be better addressed in another language till things settle a bit. A PoserPython version of MorphSqueeze is a real possibility. I'll look into it after I finish up the undo function for the FaceRandomizer script.
Grammer ( ) posted Sun, 11 February 2001 at 2:10 AM
With the propack comes dropfiguretofloorallframes. This does what you want
Terry Mitchell ( ) posted Sun, 11 February 2001 at 8:16 AM
Wow! Thanks, Grammer. I hadn't noticed that. Guess I'll have to read all of those Script descriptions in the User Guide a bit more carefully. Tell me though, I saw the droptofloor Script, but I didn't see scripting for applying it to all frames. Is there a separate Script, or am I not understanding something?
Grammer ( ) posted Sun, 11 February 2001 at 2:00 PM
it should be in the utility folder and do this for all frames
