Vue F.A.Q (Last Updated: 2024 Sep 17 9:46 am)
I was able to repeat what you described. I'm running Vue 5.06-02, build 276828. PC Win2k, pentium 4. The other thing I noticed that seemed odd was.. immediately after loading your texture through the Material editor, I tried changing the "Type" to simple, but it wouldn't accept it. When I clicked on the type, "simple material", the bead jumped back to "mixed material" on its own. The second time I clicked simple it accepted it. One other thing. I could only reproduce your bug by right clicking the material nodes, and choosing "edit material" each time until I got to level 4. If I doubled clicked the material previews to get to level 4, the level 1 node would still have the "simple blend" option set when I navigated back.
Same as FuzzyShadows - if I double click to edit then the bug doesn't occur, but it does if I right click >Edit Material..
I aslo looked that the changing type to simple on loading - click once and it reverts to mixed, click again and it stays on simple.
Most odd!!
WinXP Home Edited to add version number - 5.05-02 Build 275754
Message edited on: 06/16/2005 10:55
Gill
Thanks so much for everyone's help here. I'm going to point this link to tech support.
I believe Vue is not in error when the material is changed to simple on the level one node. When the simple button is selected, the Material Editor dispenses with the right node on level one. Thus, the new material reverts to the level 2 node that was the left-node on level one.
Message edited on: 06/17/2005 10:03
Charles
Attached Link: http://tidbit.freefronthost.com/test_material.htm
I am looking for volunteers to test Vue 5 Infinite's Material Editor.It seems I've discovered a bug in my version of Vue (PC), and e-on can't reproduce the bug.
The test procedure is simple:
Start Vue.
Load the test material onto the ground plane.
Open the Material Editor for the test material.
Navigate the Material Editor to the fourth level node. It's identified as level 4 and is comprised of a red and white node mixture.
On this level 4 node, change the mixture to 'Full blend (linear bumps)'.
That's it!
On my system, the level 1 node is normally set to a simple mixture. When the bug occurs, the first mixture is changed to 'Full blend (linear bumps)' on the level 1 node. I've tested the latest beta, the problem still exists.
E-onsoftware's tech support said they can't reproduce this bug. I spent two hours tracking this bug down, so I'm vested in it now. Besides, I'm very anti-bug. When a Vue bug gets corrected, it's an improvement for every user.
If you'd like to help, you can download the material at the link page. If you can or cannot reproduce this bug, please post your message here with your system's specifications.
Thanks guys,
Charles
Charles
