Tue, Feb 11, 2:19 PM CST
Subject: Help with Noggin's Ostrich
meselfr ( ) posted Thu, 16 June 2005 at 6:30 AM · edited Tue, 11 February 2025 at 11:29 AM
Why does it look so crappy in Poser 5.. Using either Firefly or Standard renderer the main body texture is very, very dark brown... instead of white... I have mucked with the material settings to no avail... Cheers/Thanks.
Fazzel ( ) posted Thu, 16 June 2005 at 10:38 AM
It's possible the normals are reversed.
ratscloset ( ) posted Thu, 16 June 2005 at 1:06 PM
I have it and I do not have that issue. Are your lights correct? The one issue I do have with the figure is the included Poses recenter the figure on me.
ratscloset
aka John
meselfr ( ) posted Thu, 16 June 2005 at 4:33 PM
I have tried standard lights, global lights, etc... the wings/tail look ok.. the rest is a murky dark chocolate color... Thanks, I will keep mucking with it tonight..
Ajax ( ) posted Thu, 16 June 2005 at 5:16 PM
Can you post a render? Often seeing it tells people more than reading a verbal description.
meselfr ( ) posted Thu, 16 June 2005 at 8:12 PM
Thanks.. Here is an image.. Loaded fresh, poser 5 Sr4, poser 4 renderer
Francemi ( ) posted Thu, 16 June 2005 at 11:41 PM
It looks like the texture is not applied to the rest of the body. Don't know how this could be though.
France, Proud Owner of
KCTC Freebies
Ajax ( ) posted Fri, 17 June 2005 at 4:04 AM
What's the texture for the body called? If you have another texture with the same name then the body may be displaying the other texture. If Poser has to search for the texture, it will use the first one it finds.
meselfr ( ) posted Fri, 17 June 2005 at 5:34 AM
Thanks... didn't have another ostrich model, but found another ostrich.jpg in the same runtime directory... It's a crappy brown one... Think I can fix this one from here... Cheers, thanks...
