Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Yes it's very easy. Set up the Pose area they way you want it. ie figure, lighting, display settings, etc. Then go to Edit, preferences and click on set prefered state. Then select load to prefered state. The exact terms may be a little off, I'm going from memory but that should give you the gist of it.
I am wondering if i can replace the default figure (p5 man) so say v3 or m3 loads up when i open poser? If so how would i set it up?? Thanks much much in advance ^.^
