Fri, Dec 27, 11:08 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: Problem with Mirror Raytrace
paper-tiger ( ) posted Sun, 19 June 2005 at 3:07 AM ยท edited Fri, 27 December 2024 at 7:20 AM
See the peculiar diagonal line through the raytrace, as though it's cracked down the middle? Is there a way I can fix that in poser? This is the bathroom from ratracer's cheap hotel room (of course!) and the default mirror.
SamTherapy ( ) posted Sun, 19 June 2005 at 3:16 AM
It may be the polys in the mirror surface. Try placing the One Sided Square in front and see what happens when you use that instead of the mirror.
bjbrown ( ) posted Sun, 19 June 2005 at 3:32 PM
Attached Link: http://www.keindesign.de/stefan/poser/firefaq.html
This FAQ deals with some problems with the Firefly raytracing, including work-arounds. You might find an answer there.
paper-tiger ( ) posted Sun, 19 June 2005 at 11:03 PM
Hmm, using the one-sided square with the raytracing node applied gives me just a blank black square (and yes, firefly raytracing is on, and I applied the node to the correct object.) Hm, tutorial doesn't seem to have anything specific to this issue, but looks like a good one nevertheless. Thank you. :)
nruddock ( ) posted Tue, 21 June 2005 at 4:06 PM
Make sure the square is facing towards the camera, or use the "Normals_Forward" option in P6SR1.
