Tue, Feb 18, 4:46 AM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Subject: Before I bother PhilC, WW script problem
coldrake ( ) posted Sun, 19 June 2005 at 1:30 PM · edited Sun, 16 February 2025 at 5:11 PM
I know PhilC has been really busy lately so I thought I'd post here before I e-mail him.
Every time I try to open Wardrobe Wizard in Poser 5 (with P5 SR4) I get a window with this path:
C:Program Files3DCurious LabsPoser 5RuntimePythonposerScriptsPhilCWardrobe WizardWardrobe Wizard Menu.py
and this message:
Traceback (most recent call last):
File "", line 12, in ?
ImportError: No module named p4ww
I looked and there is a p4ww.pyc
If anyone has any ideas what's wrong I'd appreciate some help. I downloaded it last night I really want to try this thing!
My PC specs:
Win XP Pro Media Center Edition 2005,
3.0 GHz Pentium 4 Processor 600 with Hyper-Threading, 800MHz FSB 2MB L2 Cache
2Gb PC-3200 400MHz DDR3 RAM,
Duel GeFORCE 6600 GTOC 128Mg graphics cards,
250 Gb hard drive with 185Gb free space
Thanks,
Coldrake
DCArt ( ) posted Sun, 19 June 2005 at 1:33 PM
I'm not sure if this helps, but it's been my experience that you have to install any Python scripts in the default Poser Runtime. You can't have it in the Downloads runtime, or in any other external runtimes you may have.
xantor ( ) posted Sun, 19 June 2005 at 1:47 PM
Deecey is probably right, with the demo at least, philc says a specific drawer that you should install the files to.
coldrake ( ) posted Sun, 19 June 2005 at 1:51 PM
Thanks Deecey, it's in the default Poser Runtime. I just got a new computer and installed everything, I don't have any external runtimes at this point. Coldrake
coldrake ( ) posted Sun, 19 June 2005 at 1:58 PM
Thanks xantor, I guess I should have mentioned it's the full version, I just bought it yesterday. I unzipped the WW runtime to my Poser 5 folder so I assume it went where it's supposed to go, it's in the only python folder I have. Coldrake
nickedshield ( ) posted Sun, 19 June 2005 at 3:26 PM
Just bought it yesterday? Have you sent in for the registration yet? It will only run in the demo mode until Phil sends you your sn.
coldrake ( ) posted Sun, 19 June 2005 at 3:32 PM · edited Sun, 19 June 2005 at 3:34 PM
Hi nickedshield, yup, got my registration yesterday and it's installed. Wardrobe Wizard won't run at all.
Coldrake
Message edited on: 06/19/2005 15:34
nickedshield ( ) posted Sun, 19 June 2005 at 5:38 PM
In order to help in isolating your problem, have you tried running any other Python scripts? And do they work? If they don't work, you probably will have to re-install P5. if they do work, double check the WW installation. Here's a screen shot of the folder tree.
destro75 ( ) posted Sun, 19 June 2005 at 7:33 PM
It looks like you need to reinstall Poser if you want to use it. From the path that you show in the first post, you have the Curious Labs folder in a folder named 3D, under Program Files. I think the paths in WW are hard coded, so you need to have the absolute default path Poser installs to. There should be no 3D folder. The correct path should be: C:Program FilesCurious LabsPoser 5RuntimePythonposerScriptsPhilCWardrobe WizardWardrobe Wizard Menu.py Hope this helps!
coldrake ( ) posted Sun, 19 June 2005 at 7:57 PM
Destro75, thank you! You're right, WW must be hardcoded, as all the other Python scripts run fine. I dragged the Curious Labs folder to the Program Files folder and it works! I always put my 3D software in Program Files3D, games in Program FilesGames etc to keep things organized and easy to find. I've never had a problem before, but this was about an easy of a fix as it gets. :D
Thanks again!
Coldrake
KateTheShrew ( ) posted Mon, 20 June 2005 at 2:33 AM
Well, I haven't tried WW yet, but if it has to be on my C: drive, then forget it. That's my win98 OS - I don't run Poser 5 or 6 in 98, I run them in 2K which is on my D: partition and I never EVER install anything to my OS partitions. All my other programs go to the E: or H: drives. I've lost too much stuff to crashes in the past - I won't go through that again (in fact, just last week I had to totally reinstall my W2K since something got screwed up and it wouldn't boot. Thank goodness I had the w98 as a backup OS or I'd have been totally out of luck). Kate (who won't use a program that won't allow installation on MY choice of drives and folders)
martians ( ) posted Mon, 20 June 2005 at 3:53 AM
Kate: The demo version - so probably this goes for the full version as well - does not have to be installed to C:. I have it installed to my programs partition on D: and it works fine. I just tried it on E: and it works fine as well. You can even have poser installed to a different folder (with the script still in the default runtime). However, you cannot have a folder name in your path starting with a number - like 3d - or the letter x (internal variable?). BTW I'm running XP, but it should work like this on W2K.
destro75 ( ) posted Mon, 20 June 2005 at 5:13 AM
Well, I have Poser and Win2K installed on my D drive as well. WW works for me too. However, my path is still correct. It is the same path as I posted above, just subbing D for the C. I understand not wanting to be told where to install your apps. I think there are reasons that the paths are hardcoded in WW though, so I don't complain, since it is a spectacular product. Coldrake, I am glad that worked for you! Now get to analyzing clothing! ;-)
KateTheShrew ( ) posted Mon, 20 June 2005 at 10:47 AM
Ahhh, thanks folks. I was starting to worry a bit there. But since it's working for y'all I shouldn't have any problem as the only poser folders I have that start with numbers are in the textures folder (3Dream hair tex, etc.). Quit scarin' me like that, will ya?? :D Kate (the easily frightened)
diana ( ) posted Mon, 20 June 2005 at 10:04 PM
I got the same error as Coldrake in WW and had to these three files: p4ww.pyc p5ww.pyc p6ww.pyc to the lib folder and it fixed it for me. I have to copy these three files to the lib folder each time there is an update to WW to keep things synchronized.
My path to the lib folder is G:appsposer6RuntimePythonlib
My path to the WW folder is G:appsposer6RuntimePythonposerScriptsPhilCWardrobe Wizard
coldrake ( ) posted Tue, 21 June 2005 at 12:04 AM
Cool! Thanks Diana! Now I can put P5 back where I want it. :) Coldrake
PhilC ( ) posted Tue, 21 June 2005 at 5:16 PM
Yes you should be able to install Wardrobe Wizard to a Poser installation that is not on the C: drive. Paths are hard coded into Wardrobe Wizard but only from Runtime down. That said I have known instances when Poser Python was not playing ball and the repositioning of the p4ww.pyc etc files to the Pythonlib folder fixed it. This is because Poser Python is "hard coded" to always read that folder.
