Thu, Feb 13, 8:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
Subject: Poser 6 Save Problem
DrowVampyre ( ) posted Mon, 20 June 2005 at 3:01 AM ยท edited Mon, 10 February 2025 at 4:42 PM
Hi. Within the past few days, a rather strange (and frustrating) problem has begun to happen when I save my scenes. The save seems to work fine, and the file isn't 0kb (as is sometimes the case when a save error occurs). However, when I reload them, the scenes are gone. Everything is in wireframe mode, the poses are totally gone, the lighting is gone: everything. This has only happened in the past few days, and I can't figure out why. Has this happened to anyone else, and if so, how did you fix it? (By the way, this is Poser 6, running on Windows XP.)
Dizzi ( ) posted Mon, 20 June 2005 at 7:30 AM
Do you have file compression enabled? I had that problem in P5 and P6 when it was enabled... Didn't occure since it's off ;-)
DrowVampyre ( ) posted Mon, 20 June 2005 at 7:42 AM
Hmm...nope, compression's off, but external morph targets is on. Could that be it?
Dizzi ( ) posted Mon, 20 June 2005 at 12:14 PM
I'd try that at least...
paper-tiger ( ) posted Mon, 20 June 2005 at 1:27 PM
I have the same problem, but the files only get corrupted when I get an Out of Memory error. I've just learned to save two different copies of everything, and switch between them - then when one corrupts, I open the other and save-as. :/ It's a pain, but less of a pain than starting over completely.
evilded777 ( ) posted Tue, 21 June 2005 at 7:55 PM
Same odd issue for me, only occaisionaly. Have yet to pinpoint any specifics. Has only started happening since SR1. Other things since SR1: The return of crosstalk? Full body morphs cease to function when similar figures are loaded in a scene (ie 2 m3, 2 m3 1 d3, etc) Sometimes can not import PZ3 files; the only way around the above issue is to create seperate pz23 files and merge them. Today I find that I sometimes can not properly import a saved pz3. Seriously thinking about going back to pre-SR1.
