First set diffuse_color and specular_color to pure black. Then set reflection value from 0.1500 to 1.0000. In your render option make sure raytracing is checked and set raytrace bounces to 4. And give the floor something to reflect off of in the background. It is probably grey because your background is grey. Not sure what is causing the waveyness. If you have texture filtering on try turning it off. Also try turning one of the shadows off on your lights, the shadows could be interferring with one another.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2193249
See linked thread for some better settings.Note once the floor is reflective the colour will be partially determined by the colour of the lights.
Use the single sided square whenever possible. Your reflections will be better for it.
What's the reason for not simply using Poser's Ground prop? What am I missing here?
There's often distortion around the polygon edges on a multi poly surface.
