Mon, Feb 10, 8:47 AM CST
Subject: Workshop 1 RODLUC - WIP
rodluc2001 ( ) posted Fri, 24 June 2005 at 3:20 AM ยท edited Mon, 10 February 2025 at 8:33 AM
some try with fake caustics...
agiel ( ) posted Fri, 24 June 2005 at 6:32 AM
Nice job on the spiral texture of the straw :) What made you decide on faking caustics ? Better control or bad results with Vue's caustic effect ?
lanaloe77 ( ) posted Fri, 24 June 2005 at 11:04 AM
Good job, Is there anything to do to fix the triangles at the top of the glass on the rim? I'm having problems with my renders of this scene with the top of the glass. I think the shadows of your backround picture don't match the shadow of the glass.
rodluc2001 ( ) posted Fri, 24 June 2005 at 11:51 AM
triangles on top drive mi crazy ! is an unresolved issue for me... about the background isn't the final background... and about caustics my try is simulating something like "photons" deviation of light in glass material, like the "big" sw like 3d studio can make with Vray or mentalray...
agiel ( ) posted Fri, 24 June 2005 at 12:46 PM
It looks like there was a problem with the conversion of the original model into a 3ds file. I will look into it tonight and post an updated version of the scene (and the glass as a separate object).
lanaloe77 ( ) posted Fri, 24 June 2005 at 5:12 PM
Thank you for the clarification and the soon to be update. Rodluc, I look forward to your next render.
agiel ( ) posted Fri, 24 June 2005 at 6:18 PM
Have a look at the thread of the workshop. I updated the scene. These triangles were weird. I rendered the same object in carrara and vue 4, vue 4 and vue infinite... the renders in Vue all had that glitch. The render in carrara did not. I ended up cutting off the top of the glass with a boolean operation to remove those triangles.
