Fri, Jan 10, 4:55 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Yet Another Pro Pack Bug!!!
Colm_Jackson ( ) posted Wed, 14 February 2001 at 6:02 PM ยท edited Fri, 10 January 2025 at 5:49 AM
Attached Link: 3D Vision
I used the 'Add Muscle Mags' Pyhon script ulility on a new figure. It works really well. Except I can't permanently delete the magnets. I delete them. Load the file in again and they are still there. Anyone know how to remove this from a Pz3??? Thanks, Colm...
shadowcat ( ) posted Wed, 14 February 2001 at 6:14 PM
Did you resave after you deleted?
Colm_Jackson ( ) posted Wed, 14 February 2001 at 6:39 PM
Yes...
PhilC ( ) posted Wed, 14 February 2001 at 8:38 PM
Did you delete the Mag base or just the magnets?
Colm_Jackson ( ) posted Wed, 14 February 2001 at 10:52 PM
No Phil, That doesn't work. They are still there. The Python Script text box comes up too when the file is loaded... Colm...
Colm_Jackson ( ) posted Wed, 14 February 2001 at 11:01 PM
Actually, I have just realised that this happens only with Pz3's and not cr2's. So a quick work around would be to save as a cr2 first and if you need a pz3 then reload the cr2 and save as pz3. ACK... Hold on, that doesn't work... The bloody things are back!!!!
milamber42 ( ) posted Wed, 14 February 2001 at 11:11 PM
Is the Add Muscle Mags a packaged script that comes with the pro pack?? Even though I do not have Lightwave or MAX, the scripting makes the upgrade worth it for me.
Colm_Jackson ( ) posted Wed, 14 February 2001 at 11:24 PM
Yes it comes packaged with PPP but it only adds one magnet to each arm. I just decided to try it on a figure I am working on as an experiment to see how well they worked. I deleted them (as I thought) and then re-saved the pz3. It seems like I am now stuck with them... The script has the potential to be very powerfull. You only have to use 'Bushi's' face randomizer to see what the future could hold...
milamber42 ( ) posted Thu, 15 February 2001 at 12:21 AM
I'm a programmer, so I already have some things planned. I want to see what I can do with python and animations.
milamber42 ( ) posted Thu, 22 February 2001 at 5:22 PM
Colm, I've got the pro pack now, but I still can not find the 'Add Muscle Mags' script. Is it part of the sample script and buttons? If not, then do you know the .py filename?
milamber42 ( ) posted Thu, 22 February 2001 at 7:52 PM
Colm, Never mind! I found it under CallBacks.
