Just set the Specular Color to white or light grey and play around with the Specular Value until you get the effect you like.
Thanks for that info. Also, if I use that method [and I'm assuming that it's a Poser 5/6 shade node], is there a way that I could save it as a MAT File? Thanks again, jlovesart [jbWStar]
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Yep, it's P5/P6. Yep, you can save it as a MAT. One thing to remember, the smaller the highlight value (Specular_Value), the more metallic the gloss will appear. It's also do-able in P4 although the names of the bits you set up are different. For the life of me I can't remember what they are called; it's been around 18 months since I even looked at P4.
Wow, SamTherapy, that's been helpful... I got my texture stuff done and all and are working on it. I hope to obtain what I'm going for. I might send a pic or two. Thank you, jlovesart [jbWStar]
Before...
jlovesart2
[jbWStar]
I have found out what it's called: it's "Highlight" and "Highlight Size"... I remember doing some of that when I was with P4 also, so that's the one.
I created that effect using MAT Pose Edit 3, the only trouble I have is making the gloss effect come on or off when I apply it to a texture. That I'll try to figure out or hopefully someone will come up w/ an idea.
Thanks SamTherapy for bringing me back to basics.
Replies are helpful.
Thanks,
jlovesart2
[jbWStar]
Most groovy! You should play around with Fazzel's suggestions, too. You'll get good results.
for V3. I'm working on a texture map, and need to know how get the lip gloss effect.
Do I have to use a creativity with Photoshop to achieve this and if so, how.
I do have Poser 6 and I have read in a Shader Node Tutorial that you can use the shader tree method, is there a way that I can do that as a MAT Pose say if I want to save it as a file of my own.
Some advice is appreicated.
Thanks,
jlovesart
[jbWStar]
