Wed, Feb 5, 9:21 AM CST
Subject: help with wings3d
darkness_02 ( ) posted Sat, 09 July 2005 at 6:21 AM · edited Tue, 28 January 2025 at 5:49 PM
Hello all... I'm trying to creat a plane wing in wings3d but are having a lot of problems with it... could someone tell me the best way of doing it... thanks from darkness...
You imagination is your only limitation.
Check out Dark Design for freebies for your own artwork.
Sitemail Dark Design
tjohn ( ) posted Sat, 09 July 2005 at 6:34 AM
I can do it, but am not good enough at it to explain it. If you post this thread in the Wings 3d Forum, you might get a quicker, and more thorough response. They are very helpful there, and no one knows Wings 3d better.
pakled ( ) posted Sat, 09 July 2005 at 11:18 AM
well..tjohn's better at wings than I, so I can't be much help. There's a way to bring a plane picture as a background, which has been used to good effect by the folks in the Wings forum. C'mon by the forum, and we'll see what we can do..;)
tantarus ( ) posted Sat, 09 July 2005 at 12:47 PM
Look the draculaz tut. here on renderosity if you already didnt. there are few neat basic technics that can help you :)
Open your mind and share the knowledge!
Paintballa198 ( ) posted Sat, 09 July 2005 at 4:42 PM
Ive been working on this one. Its a pretty exact replica of the Diamond c1 eclipse. Ive flown the plane many times but it helped to get pictures of all the angles for a basis because the aerodynamics of an airplane can be hard to model. http://www.controller.com/listings/forsale/detail.asp?ohid=1090841 The fueselage(sp?) and empenage are all one piece made from distorting a cone. Planes by nature have a lot of curves so I had to make a lot of cuts for a more natural look. The wings, propellers, and landing gear are the only seperate pieces.
Paintballa198 ( ) posted Sat, 09 July 2005 at 4:45 PM
heres another view.
pauljs75 ( ) posted Sat, 09 July 2005 at 9:25 PM
Spiffy looking sport plane there. Almost looks like you could power it down once aloft and use it as a glider. As far as the modeling goes, it looks pretty good so far. You have the general shape worked out real good. It might need some extra edges or some edges reworked because I can see some areas of funky shading in the OpenGL view. Having wireframe shots wouldn't hurt if you're looking for more pointers on modeling. If you're working from pictures remember that theres some distortion from the lens angle. If you're taking the pictures yourself, you can reduce that by getting far away and using a strong zoom. The smaller the lens angle the better. Then when using plan views (or good side on reference photos) switch to ortho mode in Wings to reduce parallax and perspective distortion. It seems that this might be why some dimensions of your model appear off when compared to the photos. If you need more accuracy still, I suppose you could get actual measurements and then arbitrarily pick a unit of choice and make the Wings unit equal to that.
Barbequed Pixels?
shinyary2 ( ) posted Sat, 09 July 2005 at 10:58 PM
Hmm... as has been said, there is a forum for this. But why not start with a cube (or just take an appropriate polygon on each side of your plane and extrude normal), take the ends and skinny them down, then use the smooth function to round out the wing?
shinyary2 ( ) posted Sat, 09 July 2005 at 11:04 PM
Something like this. =)
