Mon, Feb 3, 6:39 PM CST
Subject: The Tailor 1.5, Poser 6 and Wardrobe Wizard
pzrite ( ) posted Mon, 11 July 2005 at 4:49 PM · edited Mon, 03 February 2025 at 6:37 PM
I have The Tailor 1.5 and am realizing that it doesn't work with Poser 6 (somebody correct me if I'm wrong), so I was thinking of getting the Wardrobe Wizard. So my question to those who own it, does it work the same as the Tailor, creating morph targets from a figure and transfering them to clothing? Also is WW compatible with Poser 6?
thanks for any suggestions,
Leee Also, I read the description of WW of Phil's site, but still not sure if it will do what I want it for. Basically taking standard clothing for Vicki 3 and making them fit my morphed version of Vicki.
Message edited on: 07/11/2005 17:01
nickedshield ( ) posted Mon, 11 July 2005 at 5:08 PM
Attached Link: http://www.philc.net
WW does not add morphs to the clothing like The Tailor. What it does is reshapes the clothing to match the figure's body shape. It can maintain morphs. What I would suggest is getting the demo version and see how it acts for you. There is a new update due out that should cure the P6 issues.
wrpspeed ( ) posted Mon, 11 July 2005 at 5:14 PM
i have converted some clothing with wardrobe wizard and then tried to run it through taylor but get error message.
nickedshield ( ) posted Mon, 11 July 2005 at 5:32 PM
Did you save the converted clothing back to the library? Doing so will create the cr2 the Tailor wants to see. You should be able to load an original piece of clothing then the newly saved clothing and transfer whatever morphs you ned. I always save my converted clothing, then I don't have to mess with it when I want it. Load it up and good to go.
wrpspeed ( ) posted Mon, 11 July 2005 at 5:35 PM
yes, i did it from the saved version of the clothing
nakamuram ( ) posted Mon, 11 July 2005 at 6:43 PM
If you have Poser 5, you can setup the Poser 6 Runtime as a second Runtime. You can then open up the Poser 6 .cr2 in Poser 5 and save it back and rename it. You should be able to open the "new" .cr2 in Tailor.
pzrite ( ) posted Mon, 11 July 2005 at 6:56 PM
Okay thanks, I'll give it a try!
BastBlack ( ) posted Mon, 11 July 2005 at 7:06 PM
Just curious, Why would you want to run clothing through Tailor after converting it through WW? bB
nickedshield ( ) posted Mon, 11 July 2005 at 7:19 PM
To put certain morphs back into the clothing. I have a pair of jeans that uses a boot fit morph so I put it back in using the tailor.
nickedshield ( ) posted Mon, 11 July 2005 at 7:40 PM
Attached Link: http://renderosity.com/messages.ez?Form.ShowMessage=2208852
pzrite... I think I mis-read your post. You may want to read this thread: Incompatibility between P6 and the tailor
BastBlack ( ) posted Mon, 11 July 2005 at 9:49 PM
Wardrobe Wizard can keep your clothing morphs, so there's no need to put morphs back into a conversion. You just have to switch to Advanced Convert To, and use "Unwelded, UnGrouped". Over at PhilC's website, he has a nice tutorial with pictures that shows how to convert clothing while keeping all clothing morphs intact. Check it out: How to retaining existing morphs and body handles. http://www.philc.net/WW_tutorial1.htm bB
nickedshield ( ) posted Mon, 11 July 2005 at 10:39 PM
I've read all of the tuts. Been using it during the beta testing. Some times I do things out of the norm, works better for me. What I do may involve chopping up the obj with UVMapper, editing the cr2, whatever is needed, including using the tailor because sometimes a figure morph is the only way to get a proper fit.
BastBlack ( ) posted Mon, 11 July 2005 at 11:29 PM
Oh, okay. I do some odd ways of converting too sometimes. Sorry, i can't help you on your Tailor Poser 6 question. I can only guess what the problem is, FBM are set differently in P6? P6's compression file format? shrug bB
Tashar59 ( ) posted Tue, 12 July 2005 at 1:04 AM · edited Tue, 12 July 2005 at 1:06 AM
What happens if you go into your General Preferences > Misc. and uncheck the Use file compression and Use external binary morph targets. Edited to say, before you save back into library.
Message edited on: 07/12/2005 01:06
Kalypso ( ) posted Tue, 12 July 2005 at 1:51 AM
Site Admin
I actually like Wardrobe Wizard for the simple fact that I DON'T have to clutter my .cr2s with worthless moprhs for all eight of Vicki's breast sizes, etc :) So I just do conversions on a need to have basis, that is, I have my character fully morphed first and then do the convert to. Sometimes I don't even save the clothing cr2 since I may want to use another figure or morph the figure differently. The conversion to a figure takes about 5-10 seconds!
XENOPHONZ ( ) posted Tue, 12 July 2005 at 11:00 AM
It didn't take me very long to discover the incompatibility between the Tailor and P6.
I hope that we get a Tailor 1.6 (or something) to fix the problem soon.
The Tailor is too useful of an app to let it drop behind the development curve.
Something To Do At 3:00AM
DCArt ( ) posted Wed, 20 July 2005 at 12:26 AM
I just ran across the same problem. It's not enough to turn off the file compression; the center of mass props are presenting a problem in The Tailor. I agree ... a patch would be a good thing!
