Attached Link: http://www.philc.net
WW does not add morphs to the clothing like The Tailor. What it does is reshapes the clothing to match the figure's body shape. It can maintain morphs. What I would suggest is getting the demo version and see how it acts for you. There is a new update due out that should cure the P6 issues.I must remember to remember what it was I had to remember.
Did you save the converted clothing back to the library? Doing so will create the cr2 the Tailor wants to see. You should be able to load an original piece of clothing then the newly saved clothing and transfer whatever morphs you ned. I always save my converted clothing, then I don't have to mess with it when I want it. Load it up and good to go.
Attached Link: http://renderosity.com/messages.ez?Form.ShowMessage=2208852
pzrite... I think I mis-read your post. You may want to read this thread: Incompatibility between P6 and the tailorI must remember to remember what it was I had to remember.
Wardrobe Wizard can keep your clothing morphs, so there's no need to put morphs back into a conversion. You just have to switch to Advanced Convert To, and use "Unwelded, UnGrouped". Over at PhilC's website, he has a nice tutorial with pictures that shows how to convert clothing while keeping all clothing morphs intact. Check it out: How to retaining existing morphs and body handles. http://www.philc.net/WW_tutorial1.htm bB
I've read all of the tuts. Been using it during the beta testing. Some times I do things out of the norm, works better for me. What I do may involve chopping up the obj with UVMapper, editing the cr2, whatever is needed, including using the tailor because sometimes a figure morph is the only way to get a proper fit.
I actually like Wardrobe Wizard for the simple fact that I DON'T have to clutter my .cr2s with worthless moprhs for all eight of Vicki's breast sizes, etc :) So I just do conversions on a need to have basis, that is, I have my character fully morphed first and then do the convert to. Sometimes I don't even save the clothing cr2 since I may want to use another figure or morph the figure differently. The conversion to a figure takes about 5-10 seconds!
It didn't take me very long to discover the incompatibility between the Tailor and P6.
I hope that we get a Tailor 1.6 (or something) to fix the problem soon.
The Tailor is too useful of an app to let it drop behind the development curve.
I have The Tailor 1.5 and am realizing that it doesn't work with Poser 6 (somebody correct me if I'm wrong), so I was thinking of getting the Wardrobe Wizard. So my question to those who own it, does it work the same as the Tailor, creating morph targets from a figure and transfering them to clothing? Also is WW compatible with Poser 6?
thanks for any suggestions,
Leee Also, I read the description of WW of Phil's site, but still not sure if it will do what I want it for. Basically taking standard clothing for Vicki 3 and making them fit my morphed version of Vicki.
Message edited on: 07/11/2005 17:01
