Sun, Jan 26, 7:40 PM CST
Subject: Changing clothes with volutpuous Vicki
thenodemaster ( ) posted Tue, 30 January 2001 at 7:47 PM ยท edited Sun, 26 January 2025 at 7:20 PM
Hi all. I am sure that most of you would like to change the bikini on Volutpuous Vivki but found it very difficult if not impossible to do so. Now, i am not knocking Wyrmmaster--far from it. She is defintely a wonderful peice of work, but, I took a few hours and figured out how to replace her clothing with ALMOST anything I want and keep the "big boob" deformers on them. Here it is: To apply Voluptuous Vickis larger breast sizes to clothing, change the parent of both Gravity props from Voluptuous Vicki to Bikini Top. Once this is done, select the clothing from your library that you want to replace the bikini and click on the single check mark. When asked what to keep, select everything including current proportions. Once this is done, Select Vicki, create a pose dot for her, and then apply that pose dot to the clothing. You may need to play with the XYZ position of the body itself in relation to the figure, but that should do it. Remember, that not all clothing figures are compatible with these deformers, so, experimentation is key!!!
MikeJ ( ) posted Wed, 31 January 2001 at 3:09 AM
Thanks for the tip. :) I bought her last week too, but haven't really put any time into her yet, but this sounds like something I would have been wondering about, so I'm sure you saved me some potential aggravation with this. Again thanks, and yes, she is very well done. --Mike
duanemoody ( ) posted Wed, 31 January 2001 at 1:24 PM
Don't forget that her 'manual' is online at Geocities.
milamber42 ( ) posted Wed, 31 January 2001 at 11:14 PM
Yea, thanks for the tip! I have VV and planned on using her as a base for a new character. The $15 was well worth being able to "look under the hood" and see how wyrmmaster did it. I saw that the3dWizard has a Morph pack for Vicki's Clothing Pack 1. It has similar breast morphs and has morphs for other clothing items as well.
ecockrell ( ) posted Sun, 04 February 2001 at 6:31 PM
I'm not sure which "two" gravity props you are referring. I've only spotted one. Which, I have changed the parent to the bikini top and tried replacing without any success. Any additional help would be greatly appreciated. Thanks
milamber42 ( ) posted Thu, 15 February 2001 at 11:09 PM
ecockrell, Try this. Load VV then delete her bikini top and bottom. Select VV and load the T-Shirt from the Victoria Clothing pack using the Change Figure button. Check all three boxes -- Keep modified geomerties, Keep props attached to figure, and keep deformers attached to figure. Click OK and then check Keep current proportions in the next window and click OK. Add the modified T-Shirt to the library. The T-shirt now has all of the magnets and the gravity prop like VV. You will need to adjust the magents on the left and right collar of the T-shirt to get it to fit right. The attached picture is VV, with a new face, Z's Gel Hair, and Anton's new Vicki texture. The shirt and skirt have one of leighp1's animal print textures applied. The T-shirt is the shirt I created with the process above. Hope this helps!
duanemoody ( ) posted Fri, 16 February 2001 at 2:53 PM
Speaking of, where can I get that face?
Crescent ( ) posted Sat, 17 February 2001 at 6:21 PM
milamber42 - you're a genius! Thanks for posting that tip. I was going insane trying to get Mike's clothing to fit him after I modified him. (Grumble, I only used dials, no morphs, at that.) I'm saving clothing now for all my figures to make my life easier. Dude (or dudette) - you're a life saver!
ecockrell ( ) posted Sun, 18 February 2001 at 10:58 PM
I found out that if you do these steps it works great. 1. Replace the top with the clothing item of your choice. 2. Select Vicky, props, left_cloth_magnet_2, bring up the properties, and add the top left_collar to the deformation. 3. Repeat for the right_cloth_magnet_2.
milamber42 ( ) posted Thu, 22 February 2001 at 5:54 PM
duanemoody, Tasha's face is mine -- derived from various Vicki morphs. The texture is Anton's, with a tan color applied to Vicki. The eyes are the texture blueeye.jpg. I think it was in Freestuff a while back. The directory indicates that the file was VictorianEyes or something like that, but I did not have a readme. cresent, Thanks for the compliment, but I'm just repeating information that I have learned from the various "Gurus" here in the forums. It is probably documented in the P4 manual as well, but I tried to avoid manuals unless absolutely necessary :-) (oops...that's a Despair, Inc copyright violation!) ecockrell, I'll have to take a look at that. I had multiple magent entries, but when I installed the Pro Pack, it corrected the magnet entries.
