Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 6:57 pm)
Yea, thanks for the tip! I have VV and planned on using her as a base for a new character. The $15 was well worth being able to "look under the hood" and see how wyrmmaster did it. I saw that the3dWizard has a Morph pack for Vicki's Clothing Pack 1. It has similar breast morphs and has morphs for other clothing items as well.
duanemoody, Tasha's face is mine -- derived from various Vicki morphs. The texture is Anton's, with a tan color applied to Vicki. The eyes are the texture blueeye.jpg. I think it was in Freestuff a while back. The directory indicates that the file was VictorianEyes or something like that, but I did not have a readme. cresent, Thanks for the compliment, but I'm just repeating information that I have learned from the various "Gurus" here in the forums. It is probably documented in the P4 manual as well, but I tried to avoid manuals unless absolutely necessary :-) (oops...that's a Despair, Inc copyright violation!) ecockrell, I'll have to take a look at that. I had multiple magent entries, but when I installed the Pro Pack, it corrected the magnet entries.
Hi all. I am sure that most of you would like to change the bikini on Volutpuous Vivki but found it very difficult if not impossible to do so. Now, i am not knocking Wyrmmaster--far from it. She is defintely a wonderful peice of work, but, I took a few hours and figured out how to replace her clothing with ALMOST anything I want and keep the "big boob" deformers on them. Here it is: To apply Voluptuous Vickis larger breast sizes to clothing, change the parent of both Gravity props from Voluptuous Vicki to Bikini Top. Once this is done, select the clothing from your library that you want to replace the bikini and click on the single check mark. When asked what to keep, select everything including current proportions. Once this is done, Select Vicki, create a pose dot for her, and then apply that pose dot to the clothing. You may need to play with the XYZ position of the body itself in relation to the figure, but that should do it. Remember, that not all clothing figures are compatible with these deformers, so, experimentation is key!!!
