Fri, Jan 10, 4:56 AM CST
Subject: Speed up Rendering (For windows)
sama1 ( ) posted Sun, 18 February 2001 at 4:26 PM ยท edited Fri, 10 January 2025 at 12:12 AM
I found out a way to squeeze out a few extra Clock cycles for doing renders with Poser. Method 1) Launch Taskmanager with Poser already running; Right-Click Poser.exe and set the priority to high. Method 2) Create a batch file with the following: start /high Poser.exe %1 Place the batch in the same directory as Poser. Also in the Control Panel -> System -> Performance make sure to select the performance boost for the foreground application. Although these tricks will speed up performance they still do not beat a faster processor. I hope this helps. Sam
timoteo1 ( ) posted Sun, 18 February 2001 at 5:24 PM
Sam: So do you have any idea how much it helps? Have you done any render-time tests? I'm just curious to know the net gain. Take care, Tim
Jason Crowell ( ) posted Sun, 18 February 2001 at 7:08 PM
It's NT/2K, as far as I can tell.
sama1 ( ) posted Mon, 19 February 2001 at 6:49 AM
The start command with the /high option is WinNT, but I believe the taskmanager allows setting High Priority in Win98. Sam
sama1 ( ) posted Mon, 19 February 2001 at 7:56 AM
I should have ran tests before posting but here are the results for my system; I do not have access to a Win98 machine to test. With /high the renders took 4.75 min., without 5.75 min for a speed-up of 21% Actual results will vary based on loading of the system. I hope this helps. Sam [System: 300MHz w/ 320MB running WinNT 4.0 SP6a]
