Mon, Feb 3, 10:06 AM CST
Subject: More tech info on obj files and Poser. Need for carraige return
byAnton ( ) posted Mon, 18 July 2005 at 5:14 PM · edited Fri, 24 January 2025 at 10:43 PM
Hi there, Some may remember the older discussion about fragmented obj files and FireFly hanging up when it get's to the "adding objects" status bar. Something else that is important in the need for a hard carraige return at the end of the obj file. See below
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
byAnton ( ) posted Mon, 18 July 2005 at 5:19 PM
See this image. See the blank line at the bottom? Without it Poser get's funny. Not having it can cause long render times, errors and can even cause morph explosions if such a file is loaded as a morph. Just something to keep in mind. Anyone apart of beta testing teams might want to ref this to people. Hope it is helpful. Anton
pakled ( ) posted Mon, 18 July 2005 at 8:24 PM
hmm..I wonder if some of the lower-order ascii characters would help. Don't remember the actual numbers, but under 30 or so are a lot of control characters. To insert, type 'alt+the number of the character', like Alt+164 is and so on..hope this helps
byAnton ( ) posted Mon, 18 July 2005 at 10:40 PM
You just need the hard return.
kuroyume0161 ( ) posted Tue, 19 July 2005 at 12:21 AM
This is typically caused by a text file parser that only looks for end-of-lines (hard returns), but not end-of-file in the same breath. It may increase parsing speed, but, alas, this is the result - either an error or the last line is never parsed.
 -- Bjarne Stroustrup
AntoniaTiger ( ) posted Tue, 19 July 2005 at 3:15 AM
I know that Plain Old DOS did make use of an end-of-file marker, but even 15 years ago it wasn't used by all software. A lot of code I saw explicitly counted the file length. So relying on EOF being there is not a good idea.
Acadia ( ) posted Tue, 19 July 2005 at 4:20 AM
That was exactly the solution to fixing my long render time for that character package I was seeking help with in another thread. My render time prior to adding that carriage return at the end was almost 3 hours. After adding that to each of the 4 clothing .obj files, my render time reduced to 50 minutes. Thanks again for suggesting I try that :)
kuroyume0161 ( ) posted Tue, 19 July 2005 at 6:52 AM
I'm not talking about an EOF marker. I'm talking about checking for the end of the file (returned by most OS and language file reading routines) while reading lines from the file. If they were going by filelength (which is how I determine EOF), then a hard return at the end would be pointless to avoid the issues raised, now wouldn't it?
layingback ( ) posted Tue, 19 July 2005 at 12:37 PM
Remember Poser's origins folks. Think early MacOS conventions, not Windows, then it will make sense - or at least becomes explainable.
