-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
hmm..I wonder if some of the lower-order ascii characters would help. Don't remember the actual numbers, but under 30 or so are a lot of control characters. To insert, type 'alt+the number of the character', like Alt+164 is and so on..hope this helps
This is typically caused by a text file parser that only looks for end-of-lines (hard returns), but not end-of-file in the same breath. It may increase parsing speed, but, alas, this is the result - either an error or the last line is never parsed.
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
That was exactly the solution to fixing my long render time for that character package I was seeking help with in another thread. My render time prior to adding that carriage return at the end was almost 3 hours. After adding that to each of the 4 clothing .obj files, my render time reduced to 50 minutes. Thanks again for suggesting I try that :)
say." - Ghandi
I'm not talking about an EOF marker. I'm talking about checking for the end of the file (returned by most OS and language file reading routines) while reading lines from the file. If they were going by filelength (which is how I determine EOF), then a hard return at the end would be pointless to avoid the issues raised, now wouldn't it?
off.
-- Bjarne
Stroustrup
Hi there, Some may remember the older discussion about fragmented obj files and FireFly hanging up when it get's to the "adding objects" status bar. Something else that is important in the need for a hard carraige return at the end of the obj file. See below
"Conviction without truth is denial; Denial in the face of truth is concealment."
Over 100,000 Downloads....
