Mon, Jan 27, 12:04 PM CST
Subject: Gravel ground
viandec ( ) posted Thu, 14 July 2005 at 6:44 PM ยท edited Sun, 12 January 2025 at 11:16 PM
Hi everybody, i'm tryung to create a gravel ground with lots of little little stone like gravel. But i don't succeed in making a realistic floor. Is somebody have an idea to help me? I need relief and not juste a textured floor. Thanks a lot! vian
lingrif ( ) posted Thu, 14 July 2005 at 7:40 PM
One easy thing you can try - if you are using a .jpg for the gravel surface, use the same .jpg as a bump map.
www.lingriffin.com
silverblade33 ( ) posted Thu, 14 July 2005 at 8:15 PM
Lingrif is right. Or, you could model such a thing in another program OR..make a terrain, use a height map (greyscale image) of stoneyground to give a real rough surface :)
viandec ( ) posted Fri, 15 July 2005 at 2:41 AM
Yes that's right, i think my little mind decided to be really complicated in finding a solution... i m going to try that and wil let you know. Thank a lot for your answer,have a nice day,
Rokol ( ) posted Fri, 15 July 2005 at 5:25 AM
You could do this with 'Infinite' Just use an ecosystem of rocks, scale them down small & apply a fairly high density. It will look good, but will rack up a huge poly count affecting render times. Rokol.
diolma ( ) posted Fri, 15 July 2005 at 5:13 PM
You could try using this:-) (It's tileable) Full resolution version avaliable if wanted, just e-mail/IM me. Do not expect immediate answers, although sometime in the next week requests will be fulfilled. (Warning: full resolution version is > 3 meg in tiff format.) It won't do for large areas 'cos the pattern shows up, but for small areas (especially if they only need a couple of tiles each way), it works OK.. Cheers, Diolma
viandec ( ) posted Tue, 19 July 2005 at 1:16 AM
yes i had already try with the acosystem but the result is not so nice and take lots of computer ressources. thanks anyway! thanks also for the textured file. i m going to try to buid a terrain with some dump and then apply the texture. i will let you know the result. thanks!
