Fri, Dec 27, 10:34 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: Convert Bryce models to Poser 6?
ghoyle1 ( ) posted Mon, 18 July 2005 at 5:51 PM · edited Fri, 27 December 2024 at 6:25 AM
Is there any way to convert Bryce models to Poser 6? I do have Bryce 5, but I've only tried it out a few times. Guy
paper-tiger ( ) posted Mon, 18 July 2005 at 7:02 PM
Have you tried exporting as a wavefront obj, and then importing into Poser? I know transporting Poser figures to Bryce works that way, but I'm not certain if you can do it the other way 'round or not.
wheatpenny ( ) posted Mon, 18 July 2005 at 7:10 PM
Site Admin
You can only export Bryce models that consist entirely of imported meshes. If it is made of Bryce primitives, or even contains any Bryce primitives then it can't be exported.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
dan whiteside ( ) posted Mon, 18 July 2005 at 7:11 PM
Bryce only exports terrains, rocks and imported meshes. As far as I know there's nothing else that'll do that conversion.
pakled ( ) posted Mon, 18 July 2005 at 8:21 PM
maybe trees as well, though I could be wrong..;)
zulu9812 ( ) posted Tue, 19 July 2005 at 1:38 AM
You can only export Bryce models that consist entirely of imported meshes. If it is made of Bryce primitives, or even contains any Bryce primitives then it can't be exported. Annoying that, isn't it? I swear I'm never buying another Daz upgrade on that (5.5? Pah!) until that feature is put in.
Hawkfyr ( ) posted Tue, 19 July 2005 at 2:15 AM
Bryce doesn't export Booleans either. Bryce Booleans are not true booleans in that,they really don't modify the mesh. It just tells Bryce's render engine "Dont render this"... Tom
“The fact that no one understands you…Doesn’t make you an artist.”
dan whiteside ( ) posted Tue, 19 July 2005 at 7:47 AM
Pakled - no tree export Tom - just because Bryce does parametric booleans doesn't make it less true then a mesh boolean. In fact you're more likely to get a "true" boolean out of a parametric object then a fixed mesh.
Hawkfyr ( ) posted Tue, 19 July 2005 at 9:37 AM
Maybe..but were on the topic of export. The Boolean does not modify the mesh. If you successfully exported ,..say...a Boolean terrain(2 terrains,one negative and one positive). When you opened the object in another app, they would both be visible(positive) and neither objects geometry will have been changed. Notice how the negatives in wire-frame are still visible(dotted wire-frame,and completely visible in open GL *see image*) It may be a great solution and more efficient for Booleans within Bryce,but not for export. I'm not disagreeing with you on it's efficiency in Bryce. I'm just saying Booleans are not exportable. 8 ) Tom
pakled ( ) posted Tue, 19 July 2005 at 11:58 AM
ah..well..;) I tend to import everything into Bryce, so I claim ignernt..;) the only thing I export out of Bryce are pictures for Poser backgrounds..;) good to know, tho..;)
Boni ( ) posted Tue, 19 July 2005 at 2:56 PM
Just to let you know I've heard that there may be true exporability (and poser/texture importability) with the next incarnation of Bryce. Remember, DAZ hasn't had Bryce that long, give them a chance to do it right folks. :) Bryce originally was never intended to be a modeler, only an environment creator. The users stretched the program to do things that were not originally thought to be part of the program ... they did the same with Poser throughout the years. We as users have tested the limits and sometimes that creates larger challenges to the creators. I think both programs have evolved wonderfully over the last decade plus. We are all in this together. Boni
Boni
