Forum Moderators: wheatpenny
Photography F.A.Q (Last Updated: 2025 Feb 18 8:03 am)
I always use "auto"....it really seems to do everything just right and I would highly reccommend it...with my luck, I will take too much time setting the focus and the flash and by the time I get everything just right, it is too late to get the picture :( What are you taking pictures of, and is there any chance that the screen may be off just a bit?
IMO..cant really trust 'auto'!!! fools even the most Pro cam!!...I use manual on 'static' subjects 'cos that way, you can determine the point of focus!
It could be why your images are blurry is because of your settings?...ie, shutter speed?
you will ALWAYS find that Prosumers (like your cam) is slower than DSLR's in detecting!
Message edited on: 07/19/2005 16:28
Ah Lejimi, I also had this problem on my Fugi 602Z. Manual focus is hard. I used a tripod and and used the LCD screen with the middle of the LCD screen zoomed in. A small button next to the LCD screen on the right. this helps to see a small portion of the object larger on the screen and helps to manual focus. However, I only used this in super macro mode, mainly when shooting fish in a tank. Search the forum for 'Fred and his bruvs' to see the results. Otherwise use the autofocus, the Fugi Auto focus is very good if used properly. Good luck Steve
Attached Link: http://http://www.dpreview.com/reviews/fujifilms5100/
Lejimi, I had a look on Dreview at your camera and cannot see the LCD zoom button, rectangle and square. Also notice there is no longer a focus lock button, strange Fugi have removed these on 5500.Manuals are usually available from the manufacturers web site. Try this if you want the manual in your own language :)
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Hello, I use a Fuji Finepix S5500, and I need advices in order to set the focus manually. On the little screen my settings seem sharp enough, bur later, on the big screen, it happens to be blury... If someone could help. Thanks, Sam
