Wed, Feb 12, 3:16 PM CST
Subject: P4 versus PP
AnneCHPostma ( ) posted Mon, 25 July 2005 at 6:22 AM · edited Wed, 12 February 2025 at 3:11 PM
Hi all, This might have been addressed before, but since I am new to Poser (just bought Poser 6) and am adding content I'd like to know what the difference is in P4 or PP content. I am adding for instance ArtemisX and then I see boots in both a P4 and a PP version. Which one should I use and which one can go (i.e. which one is the best to use). At first sight I'd say the PP, if only for the reason that the P4 content is searching for .bum files that are unavailable. BTW I know P4 stand for Poser 4 and PP for Poser Pack, but because I haven't worked with Poser back then I don't know what exactly was the difference between those too. Could someone elaborate on this ? Kind regards /~nne
randym77 ( ) posted Mon, 25 July 2005 at 6:32 AM
Yes, use the PP. The difference is the bump maps. P4 uses the weird "bum" format, PP and above use regular JPGs (or other standard image formats).
But you may have to adjust even the PP materials. If you look in the material room, the bump map is often disconnected, or connected to the wrong node, unless the PP item/MAT was made with P5/P6 in mind.
AnneCHPostma ( ) posted Mon, 25 July 2005 at 6:34 AM
Thanks for the quick reply. I already suspected something could be wrong with bumpmapping. I still have much to learn ;)
kuroyume0161 ( ) posted Mon, 25 July 2005 at 9:00 AM
Actually, it's: P4 = Poser 4 PP = Pro Pack Thank ya, thank ya very much. ;)
 -- Bjarne Stroustrup
Fazzel ( ) posted Mon, 25 July 2005 at 9:59 AM
In fact if you have Poser 5 or Poser 6 keeping P4 files can be dangerous because they can cause the program to crash. Probably because it is looking for the .bum files it can't find. When I install something I immediately delete all the P4 content so I don't accidentally click on something and crash the program.
Marque ( ) posted Mon, 25 July 2005 at 11:02 AM
I have propack, p5 and p6. I always install to and empty dir and deal with anything listed as p4. Some older stuffage doesn't have the bum for propack, so you change the .bum to .jpg and it works fine. Marque
AnneCHPostma ( ) posted Mon, 25 July 2005 at 11:07 AM
Ok, but it you rename the .bum to .jpg .. then what remains the difference between P4 and PP ?
kuroyume0161 ( ) posted Mon, 25 July 2005 at 11:14 AM
The difference is that a .bum is a .bmp format using a normal direction map for bump mapping while a .jpg is a greyscale height map for bump mapping. :) Besides the applications themselves, there isn't much difference between P4 and PP content. P4 uses RSR thumbnails only, while PP can use image formats, IIRC, but that has no real effect on the content.
Marque ( ) posted Mon, 25 July 2005 at 11:18 AM
There is lots of difference btwn p4 and propack. Propack is more powerful in a lot of ways, one thing that comes to mind is the python. Marque
AnneCHPostma ( ) posted Mon, 25 July 2005 at 11:22 AM
ok So when I have to choose which to drop .. P4 will be it .. I was assuming that .. but needed to know for sure. Thanks all !
kuroyume0161 ( ) posted Mon, 25 July 2005 at 11:29 AM
Marque: Right, but we're talking content, not the apps themselves. And I think that PP,5,6 convert BUM maps for use in Poser, but don't actually create the converted file. There are ways to convert BUM maps to height maps, but it involves integration. Anthony Appleyard has a Windows app called PPP which does the job.
AnneCHPostma ( ) posted Mon, 25 July 2005 at 11:38 AM
I will look into that.
Rachel_R ( ) posted Mon, 25 July 2005 at 2:16 PM
I open P4 files in P6 all the time and it never caused a crash...even when files are missing...
Marque ( ) posted Mon, 25 July 2005 at 3:34 PM
Odd, everytime I've opened an older file that still uses .bum the program throws a hissy, and though it may not crash it is a pain waiting for it to figure out that I don't want it to keep looking. You must not have gotten a file that uses .bum in the cr2. 8^) Marque
Rachel_R ( ) posted Tue, 26 July 2005 at 8:33 AM
Somehow I knew you'd say that but not true...I just opened a chair that uses a .bum file and it didn't act up at all..
randym77 ( ) posted Tue, 26 July 2005 at 4:21 PM
I've found Poser 6 is a lot more stable when it comes to missing textures. P5 will often crash, P6 will just be really slow.
Some people don't have trouble with P5, either, but it's always been horrible with missing textures for me.
Anthony Appleyard ( ) posted Sat, 06 August 2005 at 10:26 AM
My PPP is also called IMAGEDIT. It is in the freestuff. It is not the same as Poser Pro Pack.
