Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Yes, use the PP. The difference is the bump maps. P4 uses the weird "bum" format, PP and above use regular JPGs (or other standard image formats).
But you may have to adjust even the PP materials. If you look in the material room, the bump map is often disconnected, or connected to the wrong node, unless the PP item/MAT was made with P5/P6 in mind.
Actually, it's: P4 = Poser 4 PP = Pro Pack Thank ya, thank ya very much. ;)
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
In fact if you have Poser 5 or Poser 6 keeping P4 files can be dangerous because they can cause the program to crash. Probably because it is looking for the .bum files it can't find. When I install something I immediately delete all the P4 content so I don't accidentally click on something and crash the program.
The difference is that a .bum is a .bmp format using a normal direction map for bump mapping while a .jpg is a greyscale height map for bump mapping. :) Besides the applications themselves, there isn't much difference between P4 and PP content. P4 uses RSR thumbnails only, while PP can use image formats, IIRC, but that has no real effect on the content.
off.
-- Bjarne
Stroustrup
Marque: Right, but we're talking content, not the apps themselves. And I think that PP,5,6 convert BUM maps for use in Poser, but don't actually create the converted file. There are ways to convert BUM maps to height maps, but it involves integration. Anthony Appleyard has a Windows app called PPP which does the job.
off.
-- Bjarne
Stroustrup
Hi all, This might have been addressed before, but since I am new to Poser (just bought Poser 6) and am adding content I'd like to know what the difference is in P4 or PP content. I am adding for instance ArtemisX and then I see boots in both a P4 and a PP version. Which one should I use and which one can go (i.e. which one is the best to use). At first sight I'd say the PP, if only for the reason that the P4 content is searching for .bum files that are unavailable. BTW I know P4 stand for Poser 4 and PP for Poser Pack, but because I haven't worked with Poser back then I don't know what exactly was the difference between those too. Could someone elaborate on this ? Kind regards /~nne
