Mech, thanks. Bored, but it helps Fazzel, good idea but I need to move the camera a lot so the square lose its position. I tried to parented the square with the cam, but bored again. This kind of bugs do that I continue using both Poser5 and Poser6...
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
Can you not add the background in post, I do that a lot now in P6. I save the image as a png and then add the background in post as a photoshop layer. With IBL in P6 I can match the lights first in the render and then when I add the background in post the lights are right too. Doesn't work for all things but does for most. thefixer, poser coord.
Injustice will be avenged.
Cofiwch Dryweryn.
Hi folks. I use real photos as reference of poses. Usually I load the photo in Poser as background and I set the character over it moving each part to coincide with the reference source. Sometimes, as Poser preview is too little for details, I work with the same photo in another window of a viewer software (usually ACDSee). Well, this work in Poser5. Click ACDSee, click Poser, click ADCSee... But in Poser6 I find that every time I click the viewer window for move the showed area, when I return to Poser the background dissapear!!! I need to enter in Material Room, click in Background and the pic appears again in Poser. But this system is a hell! Is this a known bug? Any solution? Bug list for e-frontier?
CASETTE
