Sat, Dec 28, 1:55 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Subject: Need some help in UF
Fractelaar ( ) posted Tue, 26 July 2005 at 1:38 PM · edited Fri, 27 December 2024 at 10:43 PM
as i use multi layers in UF then i have sometime trouble with change this layers in that layer window The first 2 layes is most not a problem but special as i use let we say 5 or 6 layers then i have many times that problem I read sometime that people use here 50 or 60 layers for one image So i do for sure something really wrong Maybe one of Dutch folks can help me with that and maybe you can explain it in simple word My English knowledge is very small Thank you Arend
sofie-filo ( ) posted Tue, 26 July 2005 at 2:02 PM
Schrijf maar in het Nederlands, Arend. Liefst met voorbeeld UPR en exact wat je wil of wil gaan veranderen. (locatie tab-formula tab-in/outside tab?) Groeten, Jos
Fractelaar ( ) posted Wed, 27 July 2005 at 2:47 AM
Thanks Jos for the help shall contact you very soen Greatz Arend
fractalinda ( ) posted Fri, 29 July 2005 at 10:47 AM
Hello Arend, If you right-click your mouse, you will see an option that allows you to move the layer up or down. You can also "copy" a layer, click on the layer below where you want the new layer and "paste." Perhaps this information is not specifically what you need. Good luck! Linda Hello zal Arend, als u uw muis met de rechtermuisknop aanklikt, u een optie zien die u toestaat om de naar boven of naar onder laag te bewegen. U kunt een laag "ook kopien", op de laag klikken hieronder waar u de nieuwe laag en het "deeg." wilt Misschien is deze informatie niet specifiek wat u nodig hebt. Goed geluk! Linda
Fractelaar ( ) posted Fri, 29 July 2005 at 10:55 AM
Thanks Linda and great to see you translate really very good I know from the layers and paste colorpallette ,s etc but i doing something wrong have to read some Tut,s and i hate to read that stuff :-) want always to bea creative Wish you a nice vacation Cheers Arend
