Attached Link: http://digitalbabes2.com/
Check out kozaburo's site (link is also under webring top 15 to the bottom right here) for the best in transmapped hair. I believe Rochr has a tut on his site for how to use it.Pass no temptation lightly by, for one never knows when it may pass again!
Thanks, I'll check it out.
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
I haven't had any luck getting Koz's hair into Bryce (and don't think I haven't tried..;) The old hair types (stock Poser stuff, Worldgate 2000's [caution, adult material], etc., will transfer over. If you can keep track of the textures, that's a big help, though I've used mats from Lunariad.com (brown hair mat, for example), which have worked. Check 'em out.
But if there is a way to use Koz's hair, I'll have to check that out..thanks..
All you must do is import the transparency map. then onc eit is applied use the pull down menu next to the testures and select blended transparency. Koz's hair works fine in Bryce if you do that.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the
person next to me.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1518353
Incarnadine said very well :) also here is one more thread about hair transparency in Bryce - here are the settings for Kozaburo hair, others work just the same :) only don't forget to choose "blend transparency".kitty5
#rendergods
Message edited on: 07/30/2005 18:07
www.Bucketload3d.com - where cool
freebies are ~(==^..^)
I've taken to creating rudimentary hair in Wings to cover my Poser figures' chrome domes.
I know that dynamic hair won't import into Bryce (or is that export out of Poser).
Has anyone found a solution to getting a mop on Poser heads in Bryce? Modelling semi-realistic hair is time consuming.
Message edited on: 07/29/2005 11:56
