Sun, Nov 3, 5:53 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 03 10:43 am)
Subject: How do you fix a broken texture
Kristta ( ) posted Sun, 31 July 2005 at 11:03 AM · edited Fri, 18 October 2024 at 10:46 AM
After I did a final render, I discovered the horrible white lines that indicate the texture did not wrap around correctly. How do you fix something like this? Thanks in advance, Kristta
TrekkieGrrrl ( ) posted Sun, 31 July 2005 at 11:57 AM
Poser 5 or 6? Someone mentioned something like this yesterday. Has to do with Texture Filtering I think
Kristta ( ) posted Sun, 31 July 2005 at 12:15 PM
It's P6.
mrsparky ( ) posted Sun, 31 July 2005 at 12:58 PM
This can happen regardless of Poser version. Remember as a kid you where told "don't colour outside the lines". ? If you do that on a texture map, the area just outide the seam or edge can show thorough, like the problem here. The solution is simple. Fire up your paint package and run a clone brush around the edges. see the attached sample image. Big Tip: Always work from a backup of your map!
