wow I never saw that :) doh, thanks zulu :)
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
Attached Link: http://www.zipgenius.it
@Kristta: You can create zip files with free utilities like ZipGeniusLe cinéma substitue à notre regard un monde qui s'accorde à nos désirs. - André Bazin
Kristta: To make the correct paths in your zip files, make a dummy Runtime folder, for instance on your desktop. In that, you create the folders needed (of it's textures with Mat poses you only need RuntimetexturesKristta and RuntimelibrariesposeKristta (of course WHAT you call the final folder is optional) Then when you're done, assuming you've got winzip installed (who hasn't?) simply rightclick on the Runtime folder you made and from the menu chose "Add to runtime.zip". That will give you a correctly path'ed zip called Runtime.zip. You can then rename it to whatever you like. This is the fastest way. To make the thumbnails: Render a 91x91 picture of whatever you want to make a thumbnail for and save it as a png. Be sure to name it the same as the Mat pose (or whatever) - you can then use P3DO Explorer to make an rsr file from the png if you want. That way it's compatible with P4 without Pro Pack as well :o)
Attached Link: http://www.daz3d.com/support/tutorial/index.php?id=766
Kristta: Mercytoo did a step-by-step tutorial over at Daz - see the link. Just about as clear as anything could be, even I can follow it :-)Steve
Hi all Not sure what anyone else thinks but we have an Artist of the Month, and a Merchant of the month what about having a freestuff provider of the month. Not sure how it would work but I just think that the people that put lots of work into providing free content and even tutorials deserve as much recognition as merchants and artists. Anyway hope that makes sense :) John
