Mon, Dec 23, 1:02 PM CST
Subject: Hair won't cast shadow
morphious ( ) posted Wed, 03 August 2005 at 6:28 AM · edited Mon, 23 December 2024 at 12:44 PM
Poser 6, IBL lighting, MAC OSX. For some reason the hair isn't casting a shadow onto the figure. I have tried adding an AO node to the skin, but no go. Anyone have an idea? Thanks.
zulu9812 ( ) posted Wed, 03 August 2005 at 6:31 AM
IBL lights are set with shadows off by default - you need to turn them on in the light's properties
morphious ( ) posted Wed, 03 August 2005 at 6:36 AM
I did. I also tried AO lighting. Also, why are there 4 lights, but on the IBL is "check" on in the properties. The sun, light 1, light 3 are "checked" off. Not to get off topic, but also was wondering about it. Thanks.
zulu9812 ( ) posted Wed, 03 August 2005 at 7:06 AM
IBL lighting only uses 1 light, again by default - you can add in more, if you want. As for why shadows aren't being cast, I'm not sure.
morphious ( ) posted Wed, 03 August 2005 at 7:08 AM
If IBL lighting is used in the default light preset, it creates 4 lights, but only one is turned on.
raven ( ) posted Wed, 03 August 2005 at 7:46 AM
Does the hair have cast shadows enabled in its' properties?
morphious ( ) posted Wed, 03 August 2005 at 7:49 AM
Yes it does.
marco-xxx ( ) posted Wed, 03 August 2005 at 12:05 PM
I noticed that if you load a IBL from the library its by default with shadows disabled and, even if you enable the shadows, don't cast them: perhaps it's one of Poser bugs. Did you use a IBL loaded from library?
morphious ( ) posted Wed, 03 August 2005 at 12:08 PM
Yes, it was loaded from the library. I turned shadows on, and there are shadow everywhere except where the hair should be creating them again the figure. Strange.
Acadia ( ) posted Wed, 03 August 2005 at 12:22 PM
I usually turn off cast shadow for hair because when I don't, I often end up with ugly black patches instead of subtle shadows... especially at the neck area. To me a shadow should be darker, but still allow you to see the shape of what is there. I never get that when I have hair casting shadows....just plain opaque ugly black voids.
lesbentley ( ) posted Wed, 03 August 2005 at 1:02 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1059682
It may be the problem described in the thread linked above.
morphious ( ) posted Wed, 03 August 2005 at 1:09 PM
It mentions "Shadowcam". Where is Poser 6 is this?
xantor ( ) posted Wed, 03 August 2005 at 1:26 PM
In the parameter dials, in the camera part.
morphious ( ) posted Wed, 03 August 2005 at 1:31 PM
Thanks. I'll give it a shot.
morphious ( ) posted Thu, 04 August 2005 at 10:01 AM
I can't find the ShadowCam anywhere?
xantor ( ) posted Thu, 04 August 2005 at 10:30 AM
The ShadowCam is not an object that you can select. It can only be selected from the parameter dials window.
morphious ( ) posted Thu, 04 August 2005 at 10:32 AM
Yes I know, but what object parameter dial am I looking at?
xantor ( ) posted Thu, 04 August 2005 at 10:44 AM
If you look in the cameras part of the parameter dials window, all the shadow cameras are at the bottom of that part.
morphious ( ) posted Thu, 04 August 2005 at 10:50 AM
I must be bone stupid. I selected the main camera, and the properties tab, and there are no dials for shadow. Can you give a 123 step please. Thanks. Sorry for the thick headedness.
morphious ( ) posted Thu, 04 August 2005 at 11:27 AM
Here's mine. No shadow cameras.
raven ( ) posted Thu, 04 August 2005 at 1:05 PM
Hopefully this pic shows how to access the shadowcams. Select the one that corresponds to the light that should be casting a shadow, then it will be available in the parameters pallette.
morphious ( ) posted Thu, 04 August 2005 at 1:10 PM
Boy do I feel stupid. Thanks.
morphious ( ) posted Thu, 04 August 2005 at 1:13 PM
I notice, that using IBL, or AO, those options are not available.
raven ( ) posted Thu, 04 August 2005 at 3:04 PM
Do you have ray-tracing enabled in your render settings? I just did a test using an IBL light and shadows only showed up properly when ray-tracing was enabled in the render settings and ray-traced shadows was enabled on the IBL light.
