Im not absolutely positive but u could try this: export the wire 4 the flag part as an .OBJ, open it in that UVmapper program, (u can download it 4 free and that wont take long, its only small) next make a new UV map, then xport it out again as an .OBJ and make sure the xport UV coordinates box is ticked... u may have to save the bitmap of the wire that uvmapper makes, and take it into your paint app. and redraw your flag so it matches up on the wireframe correctly, then save the picture, open the model in Bryce, go to the material editor and put the saved picture in the texture box, make sure the mapping mode is parametric on its default settings...it should be anyway...and there u go. There is probably an even easier way than this 2 fix your problem but you could try this if nothing else helps...
