Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Many may have noticed that Poser 6 has an annoying bug that causes the 'copy picture' function to no longer function after the first time it's used, until you restart Poser. Fortunately, this is a cooperative bug, with Windows clipboard lending Poser 6 a hand. What this means is you can simply empty the clipboard from anywhere outside of Poser, and 'copy picture' will once again work for your new render. There are several ways to do it. I usually have Paint Shop Pro running at the same time as Poser if I'm doing picture-copying, so I use the command in PSP to empty the clipboard. Also, copying/pasting image data outside of Poser will let you resume using the 'copy picture' function.
