Tue, Jan 14, 7:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
Subject: Poser 6 issue...
KeremGogus ( ) posted Mon, 08 August 2005 at 8:08 AM · edited Tue, 14 January 2025 at 7:58 PM
Hello friends, I placed my hard drive (a 80gb western digital) with 200gb Seagate Barracuda. My current Windows XP can't see the whole space and I installed Windows XP SP2. And after that my Poser 6 doesn't worked. It starts normally but closing suddenly when I try to do something (anything). I was using sp2 before too - but I guess it is different than XP with SP2 ? Any ideas, suggestions ? Is a patch available ? I am asking because I don't have much time to surf on the net. All the best... Kerem
randym77 ( ) posted Mon, 08 August 2005 at 9:05 AM
It might be the Firewall. There's one built into Windows. Try turning it off, then going into each room in Poser 6. After that, you can turn it on again if you want.
KeremGogus ( ) posted Mon, 08 August 2005 at 9:16 AM
I am using norton internet security 2003. Windows Firewall is already disabled.
Khai ( ) posted Mon, 08 August 2005 at 9:18 AM
try switching your poser 6 OpenGL from Software to Hardware...
svdl ( ) posted Mon, 08 August 2005 at 10:17 AM
Probably Norton is the culprit. Very invasive. No easy way to uninstall, it's probably best to reformat your system and install WinXP from the ground up. For security it's probably best to use a dedicated hardware router. A cable or DSL router these days is cheap, has an integrated firewall, and since they run under some Unix variant, they're not vulnerable to attacks on Windows systems. Another possibility - how old is your BIOS? Older BIOSes may not like drives larger than 137 GB. I run WinXP Pro SP2, no firewall or virus protection, behind a dedicated NAT router/firewall/virus checker. Poser 6 runs fine and fast. 300 GB disk fully usable.
My gallery   My freestuff
randym77 ( ) posted Mon, 08 August 2005 at 10:21 AM
Turning the firewall off, then entering Poser and going into each room may work for Norton, too. It has for others. You can turn the firewall back on after you've entered each room in Poser, and it should be all right. Just has to be done once.
