Thu, Feb 13, 11:04 PM CST
Forum Moderators: Staff
Subject: How to create the pz2 document
Aioria ( ) posted Wed, 10 August 2005 at 10:12 AM · edited Thu, 13 February 2025 at 11:04 PM
I have an obj, having three pictures at the same time.How do I use the pz2 proceeding the commutation the picture?
mateo_sancarlos ( ) posted Wed, 10 August 2005 at 7:58 PM
.pz2 files usually apply to figures, not objects. Your syntax is faulty; can you use Babelfish to retranslate your question?
EnglishBob ( ) posted Thu, 11 August 2005 at 4:23 AM
Is it a MAT (material) pose that you require? If so, it can apply only to an OBJ which is referenced by a CR2 (figure / character file). It can also apply to an OBJ which is in the form of a hair or prop file, but only when parented to a figure. What is your native language? There will probably be someone here who can understand it.
Aioria ( ) posted Thu, 11 August 2005 at 9:45 AM
If I have a building(.obj) and two sets of texture(.jpg).In the poser do what document type?
EnglishBob ( ) posted Thu, 11 August 2005 at 9:54 AM
You need to apply the textures (JPG) to the object (OBJ). You can do that manually - use the material room, or the material dialogue depending on what version of Poser you have.
Aioria ( ) posted Thu, 11 August 2005 at 10:26 PM
file_282211.zip
Yes,I can do that.I use Poser4.0.When I choose the object,the object change the textures with the material dialogue.How do I do that?
EnglishBob ( ) posted Fri, 12 August 2005 at 6:44 AM
I can do no better than to refer you to your manual. Chapter 11 deals with surface materials, and applying a texture map is dealt with on page 250 in the English edition.
