I assume you want to delete a prop with its parented props. The trick is this: - Load a figure, doesn't matter what - Select the parent prop - Change the parent of this prop to any body part of the figure you just loaded - Delete the figure. All props that are parented to the figure (directly or indirectly) will be deleted.
Attached Link: lesbentley's Free Stuff contributions
"MinFig" is an invisible figure that only has a Body actor, it's file size is only 5 KB.Message edited on: 08/24/2005 19:11
I'm not sure about Mac requirements, but it'll probably work (maybe Maconverter is needed) The only thing that just does NOT work on Mac (OSX) is Tkinter. So if a Python script says PC only, it is PC only.
Is this possible at all. I'm on Poser 6 Mac.
