Fri, Nov 22, 2:10 AM CST
Subject: How do I delete all children with the parent?!
PilotHigh ( ) posted Wed, 17 August 2005 at 8:28 PM · edited Thu, 21 November 2024 at 8:05 PM
Is this possible at all. I'm on Poser 6 Mac.
estherau ( ) posted Wed, 17 August 2005 at 8:44 PM
hehe!
MY ONLINE COMIC IS NOW LIVE
svdl ( ) posted Wed, 17 August 2005 at 8:55 PM
I assume you want to delete a prop with its parented props. The trick is this: - Load a figure, doesn't matter what - Select the parent prop - Change the parent of this prop to any body part of the figure you just loaded - Delete the figure. All props that are parented to the figure (directly or indirectly) will be deleted.
My gallery   My freestuff
PilotHigh ( ) posted Wed, 17 August 2005 at 9:23 PM
I don't know why I didn't think about that. Thanks again.
Nance ( ) posted Wed, 17 August 2005 at 9:34 PM
[slapping forehead] DOOH!
momodot ( ) posted Wed, 17 August 2005 at 10:12 PM
I have a figure I made by taking a ball prop into and out of the Set Up Room. I can also move all sorts of things in concert if they are parented to it, which is best done with the Hiearchy window.
EnglishBob ( ) posted Thu, 18 August 2005 at 3:55 AM · edited Thu, 18 August 2005 at 3:55 AM
lesbentley has a minimal figure (minfig) in freestuff, which is ideal for all those tricks that require a figure and don't care which it is.
Message edited on: 08/18/2005 03:55
lesbentley ( ) posted Wed, 24 August 2005 at 7:07 PM · edited Wed, 24 August 2005 at 7:11 PM
Attached Link: lesbentley's Free Stuff contributions
"MinFig" is an invisible figure that only has a Body actor, it's file size is only 5 KB.
Message edited on: 08/24/2005 19:11
PilotHigh ( ) posted Thu, 25 August 2005 at 10:23 AM
All your stuff says PC only.
svdl ( ) posted Thu, 25 August 2005 at 11:47 AM
I'm not sure about Mac requirements, but it'll probably work (maybe Maconverter is needed) The only thing that just does NOT work on Mac (OSX) is Tkinter. So if a Python script says PC only, it is PC only.
