Sun, Feb 9, 2:51 AM CST
Subject: mask question
xantor ( ) posted Thu, 18 August 2005 at 7:33 AM · edited Sun, 09 February 2025 at 2:46 AM
Hello, I was trying to make an avatar using bryce 5.0 and I wanted to render the object mask but when I selected that option the render was all black. How do I make the mask render properly?
Mahray ( ) posted Thu, 18 August 2005 at 7:38 AM
Did you select your object(s) before rendering?
Come visit us at RenderGods.
Ignore the shooty dog thing.
xantor ( ) posted Thu, 18 August 2005 at 8:12 AM
No, I forgot to do that, thank you.
Sans2012 ( ) posted Thu, 18 August 2005 at 8:41 AM
Hows that for service:)
I never intended to make art.
xantor ( ) posted Thu, 18 August 2005 at 9:38 AM
I havent used bryce recently and forgot that you have to select the objects for the mask. Is there any way in bryce to save a render with an alpha channel? I tried reading the manual but couldn`t find it there.
Sans2012 ( ) posted Thu, 18 August 2005 at 10:20 AM
No, you just have to "save image as"(the mask that is)
xantor ( ) posted Thu, 18 August 2005 at 10:33 AM
But if I want to render a scene with the alpha channel is it possible in bryce?
Sans2012 ( ) posted Thu, 18 August 2005 at 10:49 AM
Alpha channels in Bryce are used to mask out areas of mats/textures and or to create hight or bump maps. Why would you want to render a scene with an alpha channel?
Hythshade ( ) posted Thu, 18 August 2005 at 11:17 AM
You can save the mask from Bryce then bring it into Photoshop or some other graphic program like photoshop, and make the mask an alpha channel, and save as a TIFF file. You then can import the texture back into Bryce, and it will automaticlaly add the saved alpha channel. Or you could just add the mask into the transparencey slot of the texture, and save as a mat preset and re-use it over and over.
xantor ( ) posted Thu, 18 August 2005 at 11:59 AM
Sans2012 I wanted to render the scene with the alpha channel so that I could remove the background in a paint program. I use paint shop pro and I don`t know how to make the mask into an alpha channel there.
dan whiteside ( ) posted Thu, 18 August 2005 at 12:20 PM
You have to be carefull with Bryce's alpha channel 'cause that's what Bryce uses to resume (or batch) a render. In Photoshop (don't know about psp), you just open the Bryce image and the saved alpha mask. You then drag the mask to the Bryce image's Channels window, then drag that channel to the "Load channel to selection" icon. Best; Dan
xantor ( ) posted Thu, 18 August 2005 at 12:34 PM
I worked out how to do it using paint shop pro, thank you.
MoonGoat ( ) posted Thu, 18 August 2005 at 12:35 PM
In PSP its just a little more complicated than that, but it can also let you mask translucency and blurs.
pauljs75 ( ) posted Thu, 18 August 2005 at 5:24 PM
I wish PSP 6 would do .png with alpha... (It would be handy for making animations when combined with Bryce & Flash MX.) sigh (I know another workaround, but there's more steps involved.) Time to upgrade I guess...
Barbequed Pixels?
Sans2012 ( ) posted Fri, 19 August 2005 at 12:42 AM
xantor: you should have written you just wanted to remove the background. Well you figured it now, so thats cool;)
xantor ( ) posted Fri, 19 August 2005 at 8:15 AM
Sans2012 it would have been good to know if bryce can save alpha channel pictures anyway for compositing.
Sans2012 ( ) posted Fri, 19 August 2005 at 8:57 AM
Thats what the object mask is for;)
xantor ( ) posted Fri, 19 August 2005 at 10:00 AM
I meant for animation compositing, it would be much easier and more convenient if the alpha channel could be saved with the picture.
pauljs75 ( ) posted Fri, 19 August 2005 at 4:15 PM
Bryce 6 feature perhaps? PNG or TIFF with alpha could be quite handy. Not sure what other formats could carry alpha... I suppose transparent GIF too, but the pallette's quite limited on that one.
Barbequed Pixels?
xantor ( ) posted Sat, 20 August 2005 at 5:57 AM
PNG and TIFF would do, PSD files can have alpha channels, I think that TGA files can have alpha channels but I am not sure about that.
