Sun, Feb 16, 10:54 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Subject: reflection map question
wotdoin ( ) posted Sat, 20 August 2005 at 12:32 AM · edited Tue, 04 February 2025 at 12:06 PM
Hi, I am making some textures for sale that need a reflection map. Can I use the default poser 4 reflection map? I know its not redistributable but most people would have it in there files or can someone tell me if there is a tutorial out there that can show me how to make my own. Thanks, Debbie
byAnton ( ) posted Sat, 20 August 2005 at 2:13 AM
Reflection Maps are really easy. There are many ways. This one uses an outdoor photo and Photoshop
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
Here is the final map applied in Poser4.
byAnton ( ) posted Sat, 20 August 2005 at 2:15 AM
Here is the map if you want to use it. I don't mind. :)
byAnton ( ) posted Sat, 20 August 2005 at 2:16 AM
Leaving a bit of color makes all the difference and makes them more real.
byAnton ( ) posted Sat, 20 August 2005 at 2:18 AM
And these were the material settings. Default color was white
byAnton ( ) posted Sat, 20 August 2005 at 2:21 AM
Here is the Bench using another map with more color and ripples in it.
lmckenzie ( ) posted Sat, 20 August 2005 at 3:19 AM
Anton can you explain the effect the multiply options are supposed to have?
Virus ( ) posted Sat, 20 August 2005 at 3:42 AM · edited Sat, 20 August 2005 at 3:44 AM
Anton: I know this is off topic, but very nice model!! :) Regards Virus
Message edited on: 08/20/2005 03:44
SAL9000 - Hello Dr. Chandra, Will I've dream?
byAnton ( ) posted Sat, 20 August 2005 at 4:39 AM
Thanks Virus. I hope this makes sense. These two are the same essentially. The key here is "Multiply". Think of photoshop "multiply" and "color" layer properties. Mult thru lights= "multiply this map through the object tonal value where the highlights and shadows are strongest" Mult thru Color= "Color the rendered area with the object color chosen."
byAnton ( ) posted Sat, 20 August 2005 at 4:44 AM
These values affect the final rendered result Light color Texture Map Object colors Reflection Color I just check everything. :)
byAnton ( ) posted Sat, 20 August 2005 at 4:47 AM
You can also add greyscale texture maps for textured metal effects. When I did the Mil Dragon Folk (ages ago), I used greyscale maps for celtic-like patterns with the reflection maps.
wotdoin ( ) posted Sat, 20 August 2005 at 10:57 AM
Thanks, you all have been a big help. I do have painter and it has a way to make the circle maps I will try that. Thanks so much for your help! Debbie
wotdoin ( ) posted Sat, 20 August 2005 at 10:59 AM
blonderella ( ) posted Sat, 20 August 2005 at 11:44 AM
yes, thanks Anton...you've offered some fantastic info here! :D Karen
Say what you mean and mean what you say.
Rachel_R ( ) posted Sat, 20 August 2005 at 7:26 PM
This is fantastic information Anton!! I understand it now....do you have the map you used in #7? That makes a terrific metal effect. Thanks!
DgerzeeBoy ( ) posted Sun, 21 August 2005 at 12:30 AM
Just great stuff, Anton. Thanks. Thanks. Thanks.
byAnton ( ) posted Sun, 21 August 2005 at 9:18 AM
No proble. #7 is a personal map I use in my commercial products now.
