Tue, Nov 26, 3:50 AM CST
Subject: poser losing textures
zollster ( ) posted Tue, 23 August 2005 at 7:13 AM ยท edited Tue, 26 November 2024 at 1:25 AM
everytime i open a scene with david using hires textures, sometimes when i first open the file and sometimes when i render it for the first time after opening it poser asks me to locate textures/bumps. wot do i do to make it behave? thanks
randym77 ( ) posted Tue, 23 August 2005 at 7:53 AM
Do you have SR 1 installed?
zollster ( ) posted Tue, 23 August 2005 at 8:09 AM
yeah this is wot it says in the pz2 textureMap ":DAZ:Characters:David:D_BodyMapHi.jpg" 0 0 bumpMap ":DAZ:Characters:David:D_BodyBumpHi.jpg" should it be textureMap "runtime:textures:DAZ:Characters:David:D_BodyMapHi.jpg" 0 0 bumpMap "runtime:textures:DAZ:Characters:David:D_BodyBumpHi.jpg" dont want to change it incase its wrong i've also got david and all his stuff in a separate runtime to poser6
yeah. this is wot it says in the pz2 textureMap ":DAZ:Characters:David:D_BodyMapHi.jpg" 0 0 bumpMap ":DAZ:Characters:David:D_BodyBumpHi.jpg" should it be textureMap "runtime:textures:DAZ:Characters:David:D_BodyMapHi.jpg" 0 0 bumpMap "runtime:textures:DAZ:Characters:David:D_BodyBumpHi.jpg" dont want to change it incase its wrong i've also got david and all his stuff in a separate runtime to poser6
las_61 ( ) posted Tue, 23 August 2005 at 9:12 AM
Are the textures where poser is looking for them? If you moved them into a different folder then you need to change it to the correct path of where the textures are.
randym77 ( ) posted Tue, 23 August 2005 at 10:58 AM
Make a copy of the MAT file, change those lines, and see if that works. (Or you could use the original, and just reinstall if you need to.)
If you don't want to do that, contact DAZ tech support. There may be something wrong with this product. Most of us bought the David Bundle, which came with standard-res textures. If there's a problem with the high-res textures, it's possible no one noticed until now.
zollster ( ) posted Tue, 23 August 2005 at 2:49 PM
the poser gods are playing with me. restarted pc to free my ram up, load up poser and david works fine!
randym77 ( ) posted Tue, 23 August 2005 at 2:58 PM
If you're using Poser 6, make sure you have SR1 applied. The original version of P6 had some memory issues, which resulted in vanishing textures. SR1 fixed that.
zollster ( ) posted Tue, 23 August 2005 at 3:02 PM
got sr1 when i downloaded poser6 from ef
PoseWorks ( ) posted Tue, 23 August 2005 at 4:28 PM
Poser 6 SR1 can sometimes store texture paths incorrectly. In your saved file, look for anything with a mixture of Mac and PC path seperators like :Runtime/Path/To:Texture.jpg and change it to :Runtime:Path:To:Texture.jpg This bug mainly affects image maps loaded via Python, but I wouldn't be surprised if it were popping up elsewhere.
